04-12-2009, 02:53 PM | #1 | ||
Critical Thinker
Since fitting my heat shield, I have enjoyed lower engine bay temperatures and the car seems a bit more responsive after long drives.
What I would like to do though is improve the intake temperatures a bit more. There is a lot of radiant heat coming off the engine that tends to get absorbed by my stainless steel 3" intake. It does get quite hot. Ive been reading some info on past threads, and other forums about what I can do. Suggestions such as 'stick on heat shield' material to heat resistant paint options. What I would like to know is what would be best to reduce intake temperatures and whats the neatest? Im leaning towards spray painting the intake with the VHT flameproof heat resistant paint. It will take the longest to prepare but will look the neatest. The other option is to go a stick on heat shield, but wont look as good but will be quicker to fit. Any thoughts on this idea or any other alternatives you could offer?
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
05-12-2009, 11:27 AM | #2 | |||
AU DIE HARD
How would you go getting it HP coated ? they do extractors for around $200 so pipe you would think shouldn't be that much, or you would hope so
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
05-12-2009, 11:35 AM | #3 | ||
Critical Thinker
Thanks Whoosha. I might look into that. What I want is for the radiant heat & heat soak to keep out and the cool air to stay cool. Would HPC coatings do this for me?
05-12-2009, 12:14 PM | #4 | |||
Rusticating
Territory SYII RWD, BFII RTV tray |
06-12-2009, 03:06 AM | #5 | |||
Critical Thinker
06-12-2009, 04:09 PM | #6 | ||
FTF Club Moderator
Heat wrap tape that is used on extractors.
HPC coating the intake pipe. Paint or powder coat the pipe white. Bastardise a fridge and build your own fridge around your intake pipe. Ala Stav style Build your own air intake cooling system using a small radiator, an electric water pump and piping wrapped around your intake pipe. Might be a bit excessive though.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
06-12-2009, 09:34 PM | #7 | ||
Critical Thinker
I am thinking of re-routing my current air/pod filter and pipework thru the inner guard and to the back of the front bumper for cooler air flow. I think getting colder air, rather than sucking in engine air as it is now has got to be my first move. There is no point ceramic coating or insulating anything further until the air going into the engine is the coldest it can be.
Anyone agree or disagree?
06-12-2009, 09:41 PM | #8 | ||
FTF Club Moderator
I agree Shav. Issue would be there is not a lot of room in our inner guards due to the suspension and wheels unless you entered the inner guard in front of these obstacles like the T3 did with their pod filter. Once inside the guard and in front of the suspension and wheel their is plenty of room to mount and route the placement of the intake and filter. Make the filter location rather accessible because you will be cleaning it regularly.
06-12-2009, 09:48 PM | #9 | ||
Critical Thinker
thanks chief. i am assuming the removal of the front bar is a must to make the easiest possible route for the pod?
does anyone have any pics of their pods fitted in behind their front bar?
06-12-2009, 09:53 PM | #10 | ||
Rusticating
You want cold air? Have a look at page 5 of this pdf brochure.
06-12-2009, 09:58 PM | #11 | ||
Critical Thinker
um.. thanks lofty, no offence, but thats ugly :P
I really want my car to look stock with the bonnet down. Ive seen people put their pods behind the front bar before neatly. i would like to see how and where things were placed.
06-12-2009, 11:16 PM | #12 | ||
Rusticating
You want cold air and good looks? Sheesh, some people! :rolleyes:
06-12-2009, 11:28 PM | #13 | ||
FTF Club Moderator
Front bar removal is not necessary though it will make it easier. If you can remove the passangers wheel, and plastic inner guard, a few screws and clips hold it in place, this is the minimum. From there running your intake wont be hard. With anything a little bit of patience will help you out.
07-12-2009, 10:38 AM | #14 | ||
Critical Thinker
No worries chief. I might take the front wheel off and inner guard for a look at what can be done.
lofty - haha, yeah I know mate. I get picky sometimes. How dare I :P
07-12-2009, 01:39 PM | #15 | ||
Resident AFF detailer
Should be interesting to see where this goes Shav......make sure you keep us all updated with pics!!!
07-12-2009, 01:59 PM | #16 | |||
Critical Thinker
