14-12-2009, 09:00 PM | #1 | ||
Hardcore I6 Enthusiast
When i first bought my limited edition XR6 ST, it had its original exhaust with the large oval tip which filled the rear bar nicely. Had a nice deep quiet idol, and had that stock sound wihch had a "sporty" feeling to it.
Is that exhaust any different to a standard XR6 or a standard AU? OR was it all the same with different tips. OR did the VCT motor just pump out a bit more noise than the other AU motors? I can guarentee its the original exhaust, the tip wasnt re-welded and it was that reverse shaped tip which appeared to not flow with the bumper curve :P Thanks in advance!! Last edited by XR6_4EVA; 14-12-2009 at 09:01 PM. Reason: I keep writing origanal instead of original. |
14-12-2009, 09:15 PM | #2 | ||
tips dose nothing to the sound
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
14-12-2009, 09:17 PM | #3 | ||
Yes i know that....im using the tip to point out that the exhaust is genuine. The fact theres no cut and shut weld marks along the system means no one has tried to wack a different muffler or resi in.
14-12-2009, 09:37 PM | #4 | |||
Just another mock-up..
for example, i had an oval tip and changed to a dump tip and noticed a change.. also on another car, went from twin 2 1/4 to a huge oval and it changed.. not a huge change, but slightly noticeable.
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
14-12-2009, 09:39 PM | #5 | ||
on the topic though..
i'm pretty sure the XR6 had a different exhaust as standard as opposed to the other VCT engined cars eg. ghia's and fairlanes..
15-12-2009, 01:22 AM | #6 | |||
All Bran = Regular Member
Different exhaust is the reason a standard XR6 has slightly higher kW than a standard Ghia. |
15-12-2009, 07:00 AM | #7 | ||
Goes like an AU
The fairmont ghia had a 4kw resrictive exhaust. The xr6 had the same exhaust but different muffler. I have been looking at getting the exhaust done and was told that compared to the normal au i6, the vct has a nicer sound. But then again each car is different ;)
1998 Series 1 AU fairmont GHIA:King Springs lowered - Tickford VCT six - Recod transmission - full TS50 body kit - 17'' BA rims - 25% tint - full leather - Exhaust system Soon to be: Extracted (pacey comps) - Flash Tuned - Dyno |
15-12-2009, 06:38 PM | #8 | ||
probably just the HP cam
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
15-12-2009, 06:41 PM | #9 | ||
the HP and VCT's are two different engines mate...
if that what you mean...? The HP engine has a different cam and the VCT has Variable cam timing which advances at higher revs..
16-12-2009, 09:17 AM | #10 | ||
XR6 live axle has the standard Falcon 6cyl exhaust and there is a different one for the IRS. I just replaced my original AU I XR6 exhaust and added an EF XR6 system to it, very nice too.
BTW, the IRS VCT XR 6cyl has twin mufflers centre and a single at the rear. |
16-12-2009, 01:46 PM | #11 | ||
Thanks guys for the quick reply.
I feel smarter |
16-12-2009, 05:29 PM | #12 | |||
i was under the impression the vct also came with the hp camshaft
16-12-2009, 05:33 PM | #13 | ||
you might be right, but i was under the impression that the VCT was different altogether, hence why aftermarket cams for the VCT aren't readily available...
would be interesting to know for sure...
16-12-2009, 05:44 PM | #14 | ||
im pretty sure the only difference between the two was vct and non-vct and its the vct that interferes with the aftermarket cam swap
what i meant was that cam changes your exhaust note... i know its only very mild but its perhaps noticeable to the OP... perhaps you have a hole in your muffler? my mum does and it sounds awesome.. used to be dead quiet but now it sounds like a sports exhaust lol
16-12-2009, 05:46 PM | #15 | ||
fair enough.... i'll look into it...
