Old 04-01-2010, 07:01 PM   #1
daza202609
EGO F6 TURBO
daza202609's Avatar
Question ford focus xr5 turbo - boost?
hey guys,
my sister has the above mentioned car, i'm trying to find out what boost they run in stock form,
any help will be great...
EGO F6
daza202609 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2010, 12:20 PM   #2
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
most guys on here are not XR5 owners. However I'm sure you'll get your answer at www.fordxr5turbo.com
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2010, 01:35 PM   #3
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
I thought this would be an easy one to answer but after having a very brief poke around the xr5 forums I couldn't see it. It is in there though (and btw tell your sister to join the forum! It's a gold mine of info, plus it's very social)
The short answer is not a huge amount. They only run a small turbo that's pretty close to full capacity (meaning little headroom for increasing boost)
I'm gonna go out on a limb here and assume that you're looking at squeezing a few more neddies out of the car?
If so, then don't play with the turbo. The consequences will make your wallet a desert like abyss.
Instead jump on the xr5 forum and check out ecu remaps. There are several companies (most popular of which would have to be dreamscience) And how these work is by adjusting things like fuel:air mixtures, when and how hard the turbo boosts as well as throttle mapping, maybe even ignition timing... Not sure on that one. Anything contoled by the ecu it will manipulate to find more power.
But they're just the start. If you want more power out of it, get on those forums and start reading.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2010, 04:46 PM   #4
daza202609
EGO F6 TURBO
daza202609's Avatar
thanks for the info guys... i'm guessing probably around 4-6psi then, but i will keep reading.
EGO F6
Old 05-01-2010, 04:59 PM   #5
melbzetec
Old enough to know better
melbzetec's Avatar
If it helps, it is called a Focus ST in Europe, so if you search, you'll probably find far more information than you will only looking for our uniquely badged XR5
Old 05-01-2010, 05:30 PM   #6
melbzetec
melbzetec's Avatar
I've just found this entry in the ST owners club forum in the UK.(www.focusstoc.com)
Bluefin refers to a brand of OBDII handheld tuning modules in the UK.
"Hi Joe
The gauge measures upto 1.2 bar (17.4 psi), the car will generally hold around 13 psi and make peak a little higher from time to time. People have reported seeing different readings on the guage though and maybe an owner could state what they have seen.
The full 17psi should be available with bluefin fitted though i would think
Mike "
Old 05-01-2010, 11:04 PM   #7
Tj-zetec
Tj-zetec's Avatar
Sounds about right
