23-01-2010, 10:17 PM | #1 | ||
Are the Supercars on yet?
I went into Ford yesterday to get a new cable for the handbrake. i just wanted the short cable from the lever to where it connects under the seat under the ute. the guy at parts said the cable comes with the whole lever as well and they want $300+!!! is this right? Ute is 2001 with manual,
The service department also said there is adjustment in the rear brakes. i might have to look at that cos i have run out of adjustment at the lever.
A Ford win is a good win! V8 dreamteam 1st: 2012, 2021 2nd: 2015, 2016, 2020, 2022, 2023, 2024 3rd: 2014, 2018, 2019 |
23-01-2010, 10:26 PM | #2 | ||
WAGONE
from memory the handbrake cable is a 2 piece one where the cable runs from the handbrake itself through the floor then connects with the other piece to the diff.
Yeah pretty sure there is an adjustment point under the car as well so may just need to back it off at the handbrake and tension it up from under the car, just not too much tho.
Car Builds: EF Turbo Track Hack AU II XR6 sedan AU XR Sportsman Wagon AU Falcon.com page |
23-01-2010, 10:28 PM | #3 | ||
yeah. from what ive seen it's 2 pieces. but when i went to get 1 piece ford said i had to buy the whole hand brake lever aswell? seems a little weird
23-01-2010, 11:50 PM | #4 | |||
AU DIE HARD
Have you adjusted it at the disc at all ?
have a look through here for some tips http://www.fordforums.com.au/showthread.php?t=11244844
23-01-2010, 11:55 PM | #5 | ||
Flairs - Truckers Delight
Uh, why do you want a new handbrake cable?
Have you adjusted the shoes? Have you adjusted the 10mm bolt on the side of the handbrake lever itself?
25-01-2010, 01:46 PM | #6 | ||
the thread on the bolt next to the lever has been stripped so was gonna replace it.
adjusting the shoes was my next plan as i have run out of adjustment at the lever
25-01-2010, 02:09 PM | #7 | |||
