Power Wanted
Also..my telstar is an AT so what would be involved in changing the air box over to a POD? and where would it be attatched and such due to the ecu air control and such..excuse the semi retardedness in my questions as i do car body repairs and not mechanical..so my knowledge is limited
Sold one of the Telstars
Take the Airflow meter out with the top 1/2 of the box. Undo the 4 bolts inside the top 1/2 of the box. The top 1/2 and the AFM will come separate. Go to Autobarn or something and buy a pod filter adapter for a mazda, and of course a filter. Get a piece of metal (you measure) and bend it to a 90degree angle and drill some holes in it. You need one bit to go onto one of the bolts on to the AFM (since it needs to be held tightly as the Airbox wone be there anymore) and the other side of the thing you make goes onto a lone bolt on the suspension housing, (you will see it, the airbox used to cover it) oh and remember to take the lower half off of it and put the pod on. Let me tell u it sounds sik. I have a 2.2NA sitting in the backyard with a pod and exhaust and it sounds just like a WRX. (even 100% stock with the pod) best $40 i ever spent
89 626 GT-TURBO CAI - SUNROOF - ADJUSTABLE SUSPENSION - SOUND SYSTEM - CRONOS FRONT END - 4SPEED AUTO - 15PSI - EXHAUST - FRONT MOUNT COOLER - HEAVY DUTY BANDS - TORSEN LSD - DYNOED AT 145KW ATW @ 6000RPM everything after 4 speed auto is a typo |
Power Wanted
Thanks alot mate..i shall do so...yes the tx5s do have a nice bark to them
88 Telstar Ghia Sedan.....All alpine sound..hu..500w amp..300w 12 inch suub..6x9s custom fitted in front doors...6x9s on parcel shelf...little 4 inch speakers in factory positions in front..Now dropped 1.5 inches..rolling on 16s...need power! |
you cant bolt a turbo onto the NA motor, will go for 3 weeks at best
