Old 13-02-2010, 06:41 PM   #1
Boza
Boza's Avatar
Default Au sr1 v8 rough idle
Hey au gurus maybe some of you on here can help me out.
I have an au sr1 xr8 ute with 147,000kms on it but the engine has a rough idle i have replaced the leads & plugs i cleaned the maf sensor i also gave the throttle body a good clean but the car still runs like crap at idle but is smooth as silk throught the rev range it has me beat and don't know what it could be
Also can i get a few suggestions on upgrading the utes stereo its woefull at the moment.
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2010, 07:36 AM   #2
amiers
have you checked the ISC? if not give it a clean and make sure it is working. i had a rough idle problem that turned out to be the wire to the ISC was broken. so check it has power, the wire can be broken in the loom where you cant see it.
2018 Mustang GT
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2010, 09:21 AM   #3
RG
Back to Le Frenchy
RG's Avatar
If the above doesn't sort it then look at the HEGO sensors in the exhaust and the coil packs, they're only good for 80-90k.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2010, 11:22 AM   #4
Boza
Boza's Avatar
what does the isc look like and where is it located
Old 14-02-2010, 11:23 AM   #5
Boza
Boza's Avatar
are the HEGo sensor the same as the O2 sensonsor or is it another sensor in the exhaust system.
Old 14-02-2010, 03:10 PM   #6
amiers
its on the back of the throttle body, 2 10mm bolts. it's a round cylinder with a plug running into it.
2018 Mustang GT
Old 14-02-2010, 03:16 PM   #7
CFOUR
The Destroyer
CFOUR's Avatar
clean/replace you're fuel filter.
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2010, 04:27 PM   #8
Boza
Boza's Avatar
done it at the same time i did the plugs/leads even changed the oil but still runs like poo at idle
