hey everyone,
Sorry to bring up another thread along this line, but just after a clear answer. Is 8.5" rim too wide for a focus? i'v done alot of looking, just havnt found a definate answer. i read on an old thread that 9" would fit, but turning was bad. would this be the same for 8.5? very curious because the rims im looking at only come in 8.5. my car is also lowered 50mm (its quite low) this may effect the answer, i'm not sure... enlighten me ![]() cheers guys |
Knows nothing. Apparently
I used to have 18x8's on my LR and with 225/40/R18 tyres it used to scrub in the back over hard bumps quite regularly (I think it fouled where the top corner of the bumper met the wheel arch) 35 profile tyres didn't reduce it by much.
However the fronts were never a problem. It's worth mentioning that the car was at standard ride height for the zetec, which was lower than the others by a small amount. From memory I could just get a finger between the inside wall of the tyre and the front strut so you could encounter offset issues provided you can even get them on. My LV XR5 came standard with 18x8's with 225/40/R18 rubber and a much lower than standard ride height and it's fine. Plenty of guys have lowered xr's but I don't think they've had issues. I guess it depends on what model focus you own. Personaly I wouldn't go wider than 8 inch. Not only for fitment but for the cost and availability of the tyres themselves.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!! ![]() 1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here |
hmmmm. alright thanks for that. a little upsetting :( lol. iv got a 06 zetec.
anyone elses thoughts??? |
Old enough to know better
Not quite sure why that's upsetting.
The information TJ gave you about the LR Zetec (first half of his post) is no longer relevant as you have now told us that you have an 06 model. What is relevant is that his XR5 ..with lower suspension...copes fine with an 8" rim. Which means there is a possibility that 8.5 will be OK. However, I'd have to question whether there is any upside at all to having 8.5" from a performance POV Try looking on www.ffoc.co.uk , the British Focus site, as it have some better answers for you
alright will do. i would happily go 8 its just they only make the rim 8.5 for 18/19 inch.
i also sent www.european-parts.net an email yesterday asking if it would fit my model, they gave me a simple reply saying they will fit any 5x108 configuration. did not mention the 8.5 width. but ill have a look on the uk forum. thanks |
Ute Forum Moderator
![]() Join Date: Dec 2004
Look into it carefully, as you may upset the steering/suspension geometry if the offset of the rim is different from standard, this is important on a fwd car.
#7 | |||
The Focus XR5 wheels are 8" wide with 52.5 mm offset. You might be able to run 8.5" rims with a slightly lower offset - say 50mm. But you'd want to carefully check any wheel/tyre combination on the car if you run a lower offset than this.
what-tut-tut-tut
Can anyone quickly let me know what the standard and optimal offset is? Looking at some rims online and need them to fill the guards... a lot are coming up at +48, but I want the bastards to sit flush, or a good half centimeter outside of the guard.
I'm presuming XR5 brakes fit inside a 17" rim? I'm sure i'll need to start a new thread to ask about the intricacies of brake upgrades on poverty-pack 06 focuses? :P (Sorry for digging up old threads) |
"or a good half centimeter outside of the guard."
Is that what you really want? Especially since it is, AFAIK, illegal, and I'm pretty sure, guaranteed to get you a defect notice
#10 | ||||
what-tut-tut-tut
Good luck
#12 | ||
FOCUS 4x4?
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR |
#13 | ||
what-tut-tut-tut
no, focus mad offset with flares. Not asking opinions, asking a technical question. Offset?
