Old 14-06-2010, 12:37 PM   #1
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Default Moded Car and GAS NEED INFO
hey guys im on the hunt to put the mont on gas this is what has been done to it
− Pacemaker 4499 Headers
− Custom G&D exhaust
− Bigger Injectors
− Custom G&D Cam
− Large Trans Cooler
− G&D Airbox
− Custom Manifold
− Vernier Adjustable Cam Gear
− 3000 Hi-stall Converter
− 3" Metal Substrate Cat
− LSD Conversion with 3.9's done by G&D
− G&D Edit & Custom Tune
− And a few other little tweaks....
ill like to know if id have any problems convirting it to gas??
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 12:43 PM   #2
cougermoon
Mr blue
cougermoon's Avatar
Biggest problem will prob be the 4499's due to the lack of room in the engine bay, seen a few people have issues with the LPG mixer i think to get it to fit. I dont know if anything else would stop you but just a suggestion.
Good luck
Will
Venom-Red AUII Forte
Engine Mods:| 4499's Pacies | 2.5" single muffler Redback Cat back | Hi-Flow Cat | Custom intake 3" | SS CAI snorkel | BM Hi-Flow Filter |
Visual Mods:| Clear side indicators | Tickford Wings | XR dash cluster | Black gear surround and shifter | Painted brakes | 18" BF XR8 mags | Black chrome tail lights
My Build
cougermoon is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 12:46 PM   #3
mickyyyy
What gas system u considering to use??? as if u go vapour injection it may be an issue with lpg injector supply as u have a worked engine
Also get it done before the financial yr as u will get back $1750.00 but after then it goes down to $1500.00
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 12:46 PM   #4
POELWYK
POELWYK's Avatar
the 4499's are not a prob seeing as my white AU has 4499's and the gas mixer there with Heaps of room
2001 AU Falcon
Old 14-06-2010, 01:22 PM   #5
POELWYK
POELWYK's Avatar
i dont know what gas system to go with just yet but my main worry was i couldent put it on gas
2001 AU Falcon
Old 14-06-2010, 01:24 PM   #6
GK
Walking with God
GK's Avatar
Best to talk to Chris at Bluepower about how this engine will go on gas, then ask blownba about which gas setup he'd run if the car was his.
I'd reckon their advice is better than you'd get from any of us here! LOL!
And make sure you look after Krissy's car! LOL!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 14-06-2010, 01:40 PM   #7
POELWYK
POELWYK's Avatar
lol i have plans for this car good plans but i will look after it
ill have to ask chris at bulepower the car will be at bulepower this week so ill speak to him if krissy hasent
2001 AU Falcon
Old 14-06-2010, 01:50 PM   #8
mickyyyy
If u go mixer ring u may loose abit more power than usuall due to having engine mods as depending on cam size.
If u go impco with 200 mixer it may die off from say 4000rpm as it carnt supply enough but dont know this as we dont know cam specs.
Definatly speak to blownba or call his workshop http://www.amautomotive.com.au/ and id also chat to http://www.apsservicecentre.com.au/default.aspx as this crew has done a few high hp LPG setups.
Old 14-06-2010, 01:58 PM   #9
mik
mik's Avatar
a good gas bloke should be able to fit it up(if you can find one), i would`nt bother if plans are going turbo down the track, too many headaches.
Old 14-06-2010, 08:11 PM   #10
POELWYK
POELWYK's Avatar
i was thinking down the super charger track one day!!!
but i would like to have gas the the power too
2001 AU Falcon
Old 14-06-2010, 08:52 PM   #11
private9
www.TUFFCARPARTS.com
private9's Avatar
− Bigger Injectors
− Custom G&D Cam
− G&D Airbox
− Custom Manifold
You'll lose a little more power than normal but I wouldn't be too worried.
Gotta ask, why the bigger injectors, I can't see an NA AU ever maxing out standard injectors?
It's not that hard to do. My old EL had LPG turbo with 303rwkw with plenty of room for more.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 08:56 PM   #12
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
You have done all this work to make your car quicker and then if you fit a LPG mixer style system, you will fitting a restrictor to the intake system which is going rob some power even while on petrol, you should be looking at Vapour injection as a minimum so as not to drop power while on petrol
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 09:18 PM   #13
POELWYK
POELWYK's Avatar
how dose the Vapour injection systems work???
2001 AU Falcon
Old 14-06-2010, 09:28 PM   #14
ratter
ratter's Avatar
It has injectors and it's own ecu, it injects gas into the inlet port close to the inlet valve, there is no retsriction to the air intake system like a mixer ring system has.
Old 14-06-2010, 09:41 PM   #15
POELWYK
POELWYK's Avatar
how much would one of these system cost before the rebait
2001 AU Falcon
Old 14-06-2010, 09:49 PM   #16
Stattic
Stattic's Avatar
Andrew seriously leave it on petrol lol personally if it was boosted then yeah go for it but it's NA you're gonna have extra weight and lose power is it really worth it? Not like you're gonna go broke you'll still get huge km on the highway and hey mine uses far more and I'm surviving on a smaller wage lol :P
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 10:05 PM   #17
FRDGAL
GT-P #0336
FRDGAL's Avatar
Completely agree, especially since it's N/A. You will weigh it down and lose power. Petrol usage will be decided by your left foot. Control the foot - control the usage. Attached is a pic of what I use to get on highway driving out of a tank on United's 98 fuel. The pic was taken with the other hi-stall fitted not with this one. Both 3000 though so can't see why it would be any different to hwy k's. I have nothing against gas systems as you know after the debate held here the other night lol but personally, I wouldn't fit it to the fairmont if it compromised on power.
EDIT: Right foot lol not left LOL
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 10:21 PM   #18
RspecAU
BA GT-P Owner
RspecAU's Avatar
and if you can't control your right foot use the cruise contol...how do you think i get 10's out of my boss motor to and from work everyday and thats 140k's a day
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
299.5 rwkw's 12.74 @108mph ON MT's
ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
RspecAU is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2010, 10:24 PM   #19
POELWYK
POELWYK's Avatar
lol yeah but its a op im looking at as it would be cheaper to drive (it dont fuss me eather way) but its a thought and whated to see what could be done
2001 AU Falcon
Old 14-06-2010, 11:39 PM   #20
mickyyyy
how much extra weight is a lpg kit worth??? at the end of the day he will chop his fuel bill by 40% at least going vapour lpg and as u may supercharge it u should go with a eurogas kit as they have great injectors and will support ur power levels.
Im also curious about ur custom intake manifold and bigger injectors???
Old 15-06-2010, 12:00 AM   #21
PoweredByCNG
PoweredByCNG's Avatar
Agreed. The weight of an LPG system is about as much as a small passenger so realistically it's negligible in such a torquey car. If you're really worried about power, there's always the JTG system for BA-BF which also works on an AU. As long as your system doesn't need to be too customised, a gas injection (e.g. Euro Gas) system will set you back around $4000 before rebate.
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there.
PoweredByCNG is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2010, 12:04 AM   #22
Polyal
The 'Stihl' Man
Polyal's Avatar
SVI Au's are nice
Honestly dont even both with a mixer if you are going LPG.
  • 2017 Toyota Prado (work hack)
  • 2017 Mitsubishi Pajero Sport
  • 2003 CL7 Honda Accord Euro R (JDM) - K20A 6MT
  • 1999 Lexus IS200 - 1G-FE Turbo 6MT
  • 1973 ZF Ford Fairlane
Old 15-06-2010, 01:15 AM   #23
mik
mik's Avatar
i`m intrigued how long did you manage to keep it running for? my brother did it (lasted 12 months till he did a club day) , his mate also did it on a very high power level with no expense spared mid 400 rwkw, but neither could stop momentary lean outs, which lead to head problems in my brothers case and major engine rebuilds 3 or 4 times in his mates case, his mate had 3 fuel lines from the tank, 3 mixers to no avail.
Old 15-06-2010, 01:24 AM   #24
FRDGAL
GT-P #0336
FRDGAL's Avatar
The car was an R&D car for G&D Performance back in the day when for a period of time 2 tuning houses were trying to extract as much as they could from a N/A AU. Three cars were involved, the fairmont was one of them. The tuners did what they did during that period. Manifold & injector changes being part of it. So it has bigger injectors lol *shrugs* Hope that helps kill your curiosity
So back on topic, Poelwyk just do what you want with the car. I can ask Chris about it if you want but really, I think you should be the one to speak to him since it's your car & you know what you want, sorta lol.
