Old 17-06-2010, 04:51 PM   #1
ST
ST's Avatar
Default Has anybody had problems with their AU2/3 remotes dying without any apparent reason?
As the title states, i've recently had both my remotes die without any apparent reason. I made sure all contact points were touching and replaced the batteries on both but they still won't work.
Now I thought maybe the car isn't recognising the remotes anymore or they might need reprogramming but the red led doesn't even go on when I push any of the buttons.
Anybody have a clue what the go is? Seems way too coincidental that both stopped working completely at the same time.
2007 BF MKII XR6 CONQUER
ST is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2010, 05:00 PM   #2
DJM83
Barra Turbo > V8
DJM83's Avatar
mine died today
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 17-06-2010, 06:25 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I've never had an AUII/III remote i couldn't repair
and i've done dozens now
Old 17-06-2010, 07:52 PM   #4
JC
JC's Avatar
Me too. I kind of specialise in fixing them for family and friends. The 3 points that hold the battery cradle to the circuit board tend to break solder. Easy fix is to heat up the solder while holding the cradle down. once cool (about 5 seconds), try it and it will miraculously work.
Ford Performance Club ACT
Old 17-06-2010, 08:23 PM   #5
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
^^What he said, happens all the time.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2010, 10:10 PM   #6
pmpdau
Has caught the bug...
pmpdau's Avatar
yeah mine is hit and miss....think I might just invest in a new one.
How much do they usually set you back?
2006 Ford Territory TX (Black)
2004 Ford Falcon XT (Silver)
pmpdau is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2010, 10:28 PM   #7
private9
www.TUFFCARPARTS.com
private9's Avatar
Very common, as above the 3 points for the battery holder always break. Next thing they do is the buttons don't contact properly. I'm too lazy to fix, so I've got 5 sitting here that I should do something with!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2010, 11:02 PM   #8
RG
Back to Le Frenchy
RG's Avatar
My unlock button stopped working. Not surprising considering the crap that came out of it when I pulled it apart.
Old 17-06-2010, 11:08 PM   #9
JC
JC's Avatar
Don't replace the remote - fix it. They are around $75 each, so a free fix is cheaper.
If buttons don't work at all (and you've replaced the battery with a new one......)
1. Pull the remote apart (lever from the indentation on the top/bottom)
2. Remote circuit board section from the rubber buttons, taking note of how the circuit board fitds INTO the rubber button holder thing.
3. Heat up soldering iron, and with the point of the iron, solder the 3 contact points from underneath (they are each a small circle). You shouldn't need any more solder; just re-melting what's there tends to work
4. Before putting it back together, test the buttons without the rubber cover
5. If it works, you're done, if not, see next heading
If you do the above and buttons still don't work, or one doesn't work
1. Clean the small metal buttons with some WD40, metho or CRC (a small amount on a tissue/cloth and wipe over and around the small metal button
2. Before putting it back together, test the buttons without the rubber cover
3. If it works, you're done, if not, REPLACE (there is no thope if these steps don't work).
Put remote back together and test buttons now
1. If one of the buttons doesn't work, pull remote apart.
2. Get a 0.5 to 1mm thick piece of plastic - the small packets of screws you get are bunnings are ideal (you just need the packet, not the screws)
3. Cut a piece of plastic into a rectangle with one slightly angled side to fit inside the rubber button thing
4. Might as well do all the buttons while you're there
5. Reassemble remote, and test.
It should now work without having to put superman like pressure on the buttons.
OK, so now I've given away ALL my secrets.................
Old 18-06-2010, 05:22 AM   #10
adrian k
adrian
adrian k's Avatar
i have one that the light comes on, so appears to be unfunctional but it wont program to the car. any ideas?
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2010, 07:34 AM   #11
HLC
Audi S3
i used a fat wad of blue tack stuffed in the void behind the battery and case to hold the contacts down til i got a soldering iron
Old 18-06-2010, 08:30 AM   #12
JC
JC's Avatar
I use that method on my territory remote because it's got broken battery clips. Blue tack - the McGiver of stationery.
Old 18-06-2010, 08:51 AM   #13
Mr Hardware
3 points?
I only ever see 2.
Old 18-06-2010, 09:36 AM   #14
Whoosha
AU DIE HARD
Whoosha's Avatar
Come on JC you know the drill, go get pictures and do a step by step how to,then it can be added to the list . ..
oh then I may try and fix mine :
Originally Posted by Riksta
Old 18-06-2010, 10:22 AM   #15
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
So JC, we can send our broken ones to you to have fixed???
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2010, 11:34 AM   #16
ST
ST's Avatar
Hahahaha yeah JC, sounds like you have a little workshop made up especially for this. Thanks for the help, gonna give it a shot now.
Old 18-06-2010, 04:58 PM   #17
JC
JC's Avatar
I have an AU1, so send me one of your broken AU2 ones, I'll fix it, take pics, and post the pics up and the remote back!
Old 18-06-2010, 04:59 PM   #18
JC
JC's Avatar
Absolutely. Postage should be about $3 each way, and I charge nothing. Only problem is, I have no way to test if the fix works, unless you post me the car too!
Old 18-06-2010, 05:02 PM   #19
JC
JC's Avatar
Please post up results one way or another. In fact, when you do it, if you can take pics of the remote pulled apart (so top section outer casing, bottom outer casing, rubber button bit and then the top and bottom of the circuit board/battery bit, I can incorporate these in a write up for everyone. I did the above going from memory! (So Mr H, it may be 2, but I'm pretty sure it's 3!).
Old 18-06-2010, 05:35 PM   #20
Whoosha
AU DIE HARD
Whoosha's Avatar
Thats the spirit Pm me your address and there on there way or post it here and you have a new full time hobby at $10 each 200000 bogie AU remotes and you could retire in12 months
Old 18-06-2010, 07:39 PM   #21
JC
JC's Avatar
PM on it's way. And I can test (at least to get the red light going) them before sending back.
Old 18-06-2010, 10:56 PM   #22
GasoLane
Former BTIKD
GasoLane's Avatar
Then he'll will be able to buy two proper cars, instead of one car and one shoebox on wheels
Old 19-06-2010, 10:06 AM   #23
Mr Hardware
Wow you're generous JC I charge $20 a piece
Old 19-06-2010, 10:10 AM   #24
GK
Walking with God
GK's Avatar
Thumbs up
I can vouch for that! LOL!
He fixed a couple for me a few Canberra visits ago!
Last visit it was the cluster, trans cooler and front grille!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 20-06-2010, 12:43 AM   #25
JC
JC's Avatar
Probably why I'm still poor!
