Smile
The wagon started stalling on me...so I decided to fit the broad band manifold I modified about 2 years ago. So it started .What seemed like a staight forward job ended up chewing 8 hours of time.Still i am happy with the results as the car is pulling even faster. What didnt help was that my modified manifold was from an au2 not au1 and so the map sensors are totally different which led me to dismantle both manifolds to get the stock au upper manifold onto the modified lower one. The it happened..one of the bolts would not come off.It took me 50 minutes of fiddling to get it out...or I would have no car for work.
Eventually it all came together though and can honestly say that the wagon has gained more pulling power across the rev range.The difference is awesome. So..will I chase a new pb? Yes.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
![]() Join Date: Jan 2005
CAT600 is a nut that gets results. Stav, you're just a nut! And I mean that in the nicest possible way.
Smile
Yes I am.but I am also the nut who first mentioned stall convertors for the au six and was laughed at.Now theyre all using hi stall convertors. I am also the nut who asked if we can get 700 rwkws from an au falcon and was laughed off again at the time..yet extreme are achieving those results now. Yes I am a nut..but a nut who takes things that people are scared of and make them work.
Flairs - Truckers Delight
unless they're transmissions, rite?
good work on the more power you'd be getting close to the same power per litre as a modern jap 4-cyl, wouldn't you?
#5 | |||
Smile
#6 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Get you and your Nutter ideas down to Heathcote on the 24th mate and we can play
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Smile
Im gonna be in a different state on business.But how the heck are ya mate?
Smile
Now where is Sox?
Dazzler's in da house .....
![]() Glad you are re-energised ![]() |
GOOD LUCK STAV!!!
lets see what the old girl can do!
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
Lost Boost Gained Class
good luck mate looks good
2006 BF Fairmont Ghia
2001 AU Falcon |
#12 | |||
#13 | |||
GT-P #0336
![]() ![]() ![]() ![]() ~Tuned By Bluepower Racing~ |
#14 | |||
Smile
#15 | ||
Smile
Static ..Poelwyk thanks guys...
#16 | |||
Smile
#17 | |||
Smile
#18 | |||
Transmissions operate effectively through winter and in the snow regions, so a cold box would not be the cause of transmission failure. Flogging a box when it's cold may cause failure though, but drive properly and there should be no issues. I live in Canberra which has freezing winters (<0) and hot summers (>30). I have always run external bypass coolers on my transmissions and as yet have never had a transmission failure. And I do not drive like an old man, but I don't go drifting everywhere either.
#19 | ||
Go Stav .... I should drop in for a chat ... and get those gauges installed on the ute as well.
Has been ages since we last caught up. As for boxes though ... regular maintenance is needed ... I did put an external cooler ... but used a much better replacement ADRAD radiator and used the internal cooler in that as well on the AU. After my first trans died (due to the first owner ... Cronulla Council ... failed to service the damn thing) ... I had a rebuilt box put in (built originally for boosted application) and kept it serviced. Even though i ran load on it all of the time and manually shifted the thing ... it was still like new when i traded it in. And this is with sitting in Sydney traffic in the heat as well ... god knows what temps it would see ... i didn't have a gauge to report it unfortunately.
#20 | |||
You can't stop the signal
Good on ya stav. Great to see you back in the swing of things. You keep on fighting the good fight.
I can relate to how you’re feeling to. Haven't worked on my ute for ages but with a recent dash conversion not going to plan, for the last two weeks if I haven't been at work, I'm in the garage getting it working. And guess what? I'm loving the ute and tinkering with it more than ever. Cheers
#21 | ||
Go the wagons
AZZA
1967 XR Falcon Wagon, Super Pursuit…….for now. *****XR PARTS WANTED******* |
#22 | ||
Capri GT/TS50/GTR
go stav
au section has always been missing something when you arnt racing the wagon |
#23 | ||
Smile
Thanks guys I almost blushed when I saw this but remembered the hairs on my chest lol.
The wagon has alot more low to midrange torque and I still havent tuned it. Very busy with work so one thing at a time. A good stall convertor and then some way to make the car stay on the ground .Then we should be right to go. ![]() Its easy to get excited about things so I thing to take each day as it comes and race it first to see what it is doing then tweak it.. Hopefully it will run a flat 14 but after 2 years of daily driving I would be glad with a 14.9 or quicker.
