Old 29-12-2007, 07:27 PM   #1
xr8AU2
Question IAT sensor
Im running dual fuel on my ute and just found the IAT sensor floating around under the airbox still plugged into its harness, as far as i can gather who ever installed the lpg system either couldnt be bothered fitting it to the air intake (has been modified to fit the mixer) or its not needed........could this affect the running of the car when running on petrol / gas if not connected.
xr8AU2 is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2007, 08:04 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Definitely needs to be plugged in, between TB and MAF
2024 F150 XLT
Old 29-12-2007, 10:28 PM   #3
JC
JC's Avatar
It's not really needed at all, except that the engine is going to be thinking that the air you are drawing in through your intake is hotter than it actually is, so it should be running richer, I would think.
Ford Performance Club ACT
Old 30-12-2007, 07:37 PM   #4
xr8AU2
could this cause one of the o2 sensors to run rich
Old 30-12-2007, 11:40 PM   #5
b2tf
b2tf's Avatar
Nup, not directly related.
2024 F150 XLT
Old 31-12-2007, 01:11 AM   #6
JC
JC's Avatar
The engine may run rich, and if it does, the O2 sensor will pick up that reading - default tune on most cars is to run rich, as it does less damage overall than running too lean.
Old 31-12-2007, 01:20 AM   #7
CAT600
I miss my wheelbarrow
CAT600's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always willing to help out fellow AFF members... Technical Contributor: For members who share their technical expertise. - Issue reason: Daniels knowledge of modular engines and superchargers is extremely valuable to the AFF community. I have learnt quite a bit just reading his build threads. His contributions are often utilised by other members.
IAT dictates spark moreso than fuel. Fuel is controlled primarily by the MAF sensor.
(coolant/air temps only slightly, like enrichment on cold startup)
Higher (False) air intake temps will effectivley retard timing to prevent pinging.
Daniel
CAT600 is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 08:43 AM   #8
xr8AU2
thanks for the feed back fellas!!
Old 16-09-2010, 02:36 PM   #9
Blackery
hey i didnt know how to actually make a post so i thought i would ask on here
where is my IAT located on my 05 ford ba?
Blackery is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2010, 03:04 PM   #10
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Blackery, you have asked a question about a BA, without specifying what motor, in the section for AUs in a post about Windsor V8's. Probably post a brand new thread in the BA section with some reference as to what motor you're running (NA I6/egas I6/turbo I6/Boss V8 etc)
