Old 14-09-2010, 07:29 PM   #1
terryk
When Only The Best WillDo
terryk's Avatar
Default Mickey Thompson ET Street Radials
Hi All
Has anyone fitted M/T ET Street Radials 275/40/17 on standard 8 inch rims and did they clear the wheel well and quarter lip? On the M/T web site they recommend 9 to 11 inch rims, but I would like to maintain the standard appearance.
Terry
_______________________________________________
FGX XR8 Victory Gold Manual
FG XR6T, 13.1@108 STD
98 AU1 XR8-347, 12.20@115
74 XB/C Ute-572, 9.06@147
69 Mustang Mach1-390, 13.5@104
terryk is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2010, 07:32 PM   #2
JOSH
JOSH's Avatar
Originally Posted by terryk
Hi All
Terry
i run them on 8.5's, not sure if they will fit on 8's?
03 BA Pursuit
Blue Power Racing Developments
(03) 93053000
Ray Prescott Auto
(02) 49902488
JOSH is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2010, 08:15 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
I have them on S1 XR8 Mags and they clear fine
Originally Posted by Riksta
Old 14-09-2010, 08:27 PM   #4
terryk
terryk's Avatar
Thank you both
Terry
Old 14-09-2010, 09:28 PM   #5
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Hey Terry just noticed your 12.5 1/4 in the AU Power and times thread, Great work!!
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2010, 08:30 PM   #6
terryk
terryk's Avatar
Thanks Craig, I ran it again last night with the MT's on a set of 17x9in rims, it ran 12.373 with a 1.816 60', getting there, my target is somewhere into the high 11's. I think the fuel system need some $$$'s spent on it.
Old 23-09-2010, 09:14 PM   #7
CRAIGAU3220
Cat be Still !!!
Better again there Terry.
Care to share your build specs?
Cheers, Craig.
Old 26-09-2010, 07:37 PM   #8
terryk
terryk's Avatar
The list is long, the only thing that still has a ford part number is the block and sump.
Here is a brief summary
Eagle steel crank 3.4
Scat rods 5.4
Probe pistons
comps a little over 11:1
Probe main girdle
Romac balancer and vernier timing set
Comp Cams HR cam lifters springs and rockers
AFR 165 heads
TFS R intake
BBK 80mm TB
32lb injectors
10.5 TCE converter 3800rpm
3.9 rear end
It made 290kwrw
Old 26-09-2010, 09:23 PM   #9
CRAIGAU3220
Cat be Still !!!
Thanks for the info Terry.
Oh forgot to ask, hows the traction wth the MT's?
