Old 03-10-2005, 04:35 PM   #1
jamef
EFXR custom
Unhappy BA 4.0L in Series 1 EF
Fully rebuilding EF and debating over engine rebuild. Have considered the JMM DEV5a kit but also have the opportunity of getting a motor, gearbox and all bits from a wrecked BA. Does anyone know of any engine swaps and what needs to be changed to fit the BA 4.0L. Have heard that crossmember is an issue but have seen several cars in Magazines with the transplant done. If successful will add Vortech supercharger to aim at 300kw.
jamef is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 04:38 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
do a search on these forums for 'jetxr' , you will answer most of your questions as to fitting the BA 4.0L
Owner of first ever car to retrofit BA SSS - the EA2BA
Send me a PM if you want to know anything
2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
EA2BA is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 04:50 PM   #3
GenesiS
*Smart *** comment here*
GenesiS's Avatar
yeah i have a few articales on that jetxr here at home in strreet machine and performance fords... that thing is nuts... theres a lot of mods, probably the most obvious one to the outside world is you won't be able to close your bonnet with the BA engine in it... the jetxr had a hole cut in the bonnet, but the way it was done it looked awesome...
GenesiS is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 04:51 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
JETXR is also not engineered certified, nor has it been registered due to this fact.
Old 03-10-2005, 04:53 PM   #5
EFFalcon
Last warning
EFFalcon's Avatar
it is registered.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 03-10-2005, 04:55 PM   #6
GenesiS
GenesiS's Avatar
Originally Posted by EFFalcon
it is registered.
yeah im pretty sure it is road registered...
Old 03-10-2005, 04:59 PM   #7
EFFalcon
Last warning
EFFalcon's Avatar
does installing a later model engine require engineering?
the turbo install is fine since it was standard on the engine, but i'm not sure what the legalities are with the later model 4.0 being installed.
either way, theres plenty of other things not legal on that car so i doubt they care :P
Old 03-10-2005, 05:20 PM   #8
Rmyers
Does Steve have a car?
Rmyers's Avatar
Any engine that will yeild a 20% increase in power (over the most powerful available for your model) requires by law to be engineerd...
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 05:23 PM   #9
EFFalcon
Last warning
EFFalcon's Avatar
shoulda guessed you'd know
Old 03-10-2005, 06:50 PM   #10
vegabass
BASS ON BOARD!
vegabass's Avatar
Default Engine mounts
i believe he lowered the engine mounts and the bastard still didnt fit!!!
EL .....BA TURBO ......the mind is in overload
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
