17-11-2010, 06:30 PM | #1 | ||
T3 TE50 Blueprint
Could somebody in the know please tell me if this is the correct steel replacement balancer for the AU 220 engine? 6.4" 50oz counterweighted outer ring. I hope the link works.
Thanks. -Craig http://www.rocketindustries.com.au/d...rtno=PB1084-SS |
17-11-2010, 06:46 PM | #2 | ||
T3 TE50 Blueprint
A bit more research tells me I need the one with the inbuilt crank trigger pulley- part no. PB1463-ST.
Do the AU3 XR8 ones normally give trouble? |
17-11-2010, 08:03 PM | #3 | ||
Yep, they spin the outer on the rubber and vibrate, very common thing.
Powerbond make a good one for reasonable $$$, no point getting an orig one again. They have the main pulley and the crank trigger sprocket built in, so only one bolt to put on and they are 50 oz balance, im sure the part number you posted is the powerbond one. |
18-11-2010, 01:28 AM | #4 | |||
Cat be Still !!!
18-11-2010, 08:06 AM | #5 | ||
T3 TE50 Blueprint
Thanks Fellas, much appreciated.
21-11-2010, 09:14 AM | #6 | ||
Back in black
What symtoms am I look for?? I have a small vibration at low revs when stopped or just rolling in Drive. Don't seem to notice it when I have a the pedal down.
Black Mac TE50 S3 NO: 106 Little Mac AU S2 XR8 Bite the snake before it bites you! ______________ _.__ /________...\ _.._(___\\___//___) .._..(O...\____/...O) |
21-11-2010, 10:33 AM | #7 | |||
21-11-2010, 01:20 PM | #8 | ||
ross tuffbond balancers are far superior to powerbond. the fellow whom runs powerbond borrowed ??????? tuffbond designs !!!!!!, i know this as i worked for tuffbond in its infancy
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
23-11-2010, 09:12 AM | #9 | ||
V8 AU Fairlane
I get the same terrible vibration at those rpm's and the local Ford mechanics looked at the harmonic balancer and said it wasnt that. Anyone else have any ideas before i take it to somewhere else to get the balancer done?
Thanks Pete. |
23-11-2010, 01:37 PM | #10 | ||
I have a slight vibration at about 1200rpm and again at about 2100rpm.
Have tried to check that balancer lines up at TDC cylinder 1 but I find the ol' screwdriver down spark plug hole trick very hard, as it's hard to determine when the piston is right up the very top before it drops again. Is there any other way of checking if the balancer has spun?
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
26-11-2010, 04:47 PM | #11 | ||
there are balancers on ebay for 150 bucks at the moment
26-11-2010, 07:27 PM | #12 | |||
26-11-2010, 07:39 PM | #13 | ||
Ford T3 Partsologist
we can do Brand New Powerbond HB1463-N $205.00 or PB1463-ST $295.00 plus postage
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org |
03-01-2011, 08:52 PM | #14 | |||
04-01-2011, 04:55 PM | #15 | ||
go ross tuffbond.
http://www.rosstuffbond.com.au/
