Old 03-01-2011, 07:45 PM   #1
SVR73
Mr Polish
Default New Suspension for the XR - differing opinions help?
g'day guys
I'm thinking about lowering the front of my car 1/2 to 3/4 of an inch with either Eibach or Koni springs
some people I've spoken with say its not good to lower the car more than 1 inch because the rear IRS geometry will be changed and the rear camber will become more negative and chew the inside tyres out and then I gotta spend more money fitting camber/castor kits
then of course there is the ride quality. I dont want it to go south. its lovely as it is with standard tickford ride height but the whole car is sitting equal, not the front being lower than the rear
I want to give the front nose a drop so it gives the car a swoopier look
what are the original tickford spring and shock measurements?
If I decide to lower the front sooner rather than later, is it bad to leave the rear in standard form. can i get by with just doing the front without any problems later on
the car is up on the hoist right now in our race team HQ and I value your opinions
I dont want to get defected, have the ride become crap and make the stance worse than it already is
I am going to contact a suspension expert here in Adelaide who specialises in old school muscle and comes highly recommended for modern fords too.
as said above, my main concern is putting extra pressure on the IRS and screwing up its geometry by lowering it by 1 inch or more and chewing tyres. just for the sake of looks.
thanks guys, I value your opinions
Detailology colour fx detail studio and R&D Lab
SA's leader in auto detailing and paint treatments
SVR73 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2011, 08:19 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
I used super lows all round on mine dropped the front about 2" and the rear 1" with no adverse affect on the IRS then had a 4 wheel alignment the rears stayed near enough to the same as from the factory , front needed just a bit of a tweek , but got away with out a caster camber kit.it seems to vary a bit from car to car but for a 1" lower at the front than the back which is about ware mine ended up I can't see any problems
Originally Posted by Riksta
Old 03-01-2011, 09:30 PM   #3
BIGJB
BIGJB's Avatar
Same as Woosh here, i have sl kings right around in the Ghia with koni yellows and the ride is beautiful.
I had to have a Camber kit in the front and as Woosha has said the rear near stayed the same.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2011, 10:08 PM   #4
T3man
T3man's Avatar
Lower the front 3/4 inch and you won't have any problems whatsoever with either the front or rear camber (unless the car has had accident damage that hasn't been put back to factory spec).
Even if you dropped the front an inch or more you still won't have any issues at the back. You may have to fit a camber kit in the front though.
The rear IRS on XRs already has camber adjusters and they have plenty of scope so never need replacing that I have ever heard.
Old 04-01-2011, 01:44 AM   #5
Day-mow
rexnet
Day-mow's Avatar
if you only want to lower the front. i think eibach do a spring thats shorter then a low but taller then a super low. i know blue oval is running these and he's very impressed with them.
standard XR heigh is low.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 03:04 PM   #6
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
Matt's pretty aware of how mine sits at the moment with Eibach's. That being said, they are lower than 1". I think Matt is better off getting something that's less than 1" lower than standard XR height so that it doesn't look too uneven front and rear.
Kings low is pretty much what I would recommend based on Matt's requirements. There should be enough room for wheel alignment.
When I fit my springs, I fitted the castor camber kit, but never really adjusted the camber much. Currently Im running 1.2-1.5deg negative camber to both wheels and 0.2mm toe in. Its just enough to avoid massive tire wear, and gives excellent handling and turn in.
*disclaimer: the above specs work best with my car application choice, individual driver application & vehicle assessment is required for your car and should be checked by a professional. Some tire wear does happen with the above specs but it is marginal if tires aren't rotated regularly.*
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 03:09 PM   #7
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
I put King Springs Super Lows in the fairlane,
front end needed shimming and the rear end needed the adjustable camber bolts.
Heasman's steering did the alignment, we did the spring swap!
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2011, 06:56 PM   #8
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
On the subject of ride height. When you go to your suspension bloke, they should have the specs on hiow low you can go, to stay legal height. If they don't, get onto the transport dept website, or ring Regency park and get the info from them.
As for the camber issues. Only lowering the car will determine what else is needed. All the rest is speculation.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 04-01-2011, 11:41 PM   #9
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
I also have the Eibach's, they are excellent.
Order direct from the factory - $220
http://www.eibachdirect.com/p/523840/pro-kit.html
They also have a free shipping promotion until January 10th.
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2011, 12:07 AM   #10
Day-mow
rexnet
Day-mow's Avatar
lame dont say that. i paid 255 for kings :(
Old 05-01-2011, 10:39 AM   #11
blueoval
Critical Thinker
blueoval's Avatar
With the US dollar being equal or better than equal to AU$ its really a simple choice to get the Eibach's. They just feel more superior in my opinion, and this is coming from someone who has had Kings, Aurora, and Pedders springs.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 05-01-2011, 02:25 PM   #12
mik
mik's Avatar
i like the look of a lowered limo, but mine scrapes enough on the masses of dodgey gutters and speed humps in good old nth Melb, not to mention trying to get it on ramps or jacking the mongrel, how do you guys get by ?
Old 05-01-2011, 02:32 PM   #13
blueoval
Critical Thinker
blueoval's Avatar
Mine is fine on speedhumps and gutters. No scraping unless I have a full car load. Only place I had issues was getting on a ferry from Kadina to Pt Lincoln. But I always take it real slow getting over speed humps etc anyway.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 05-01-2011, 03:35 PM   #14
Dave_Obsession
I'm fine also - the rear mudflaps may scrape sometimes depending on the size of the speedhump, what's in the boot etc....but no problems otherwise, even with a full car.
Old 05-01-2011, 03:39 PM   #15
T3man
T3man's Avatar
I have to watch every little dip. And to jack it up I first have to drive it onto boards. And that's not even lowered!!!
Old 05-01-2011, 05:19 PM   #16
Day-mow
rexnet
Day-mow's Avatar
im ok on speed humps. sometimes i get stuck going in and out of drive ways. to combat this i just go wide and turn so im kinda parallel almost with curb.
this is due the the fact i have a TS 50 bar as well as SL springs.
as for jacking i use the side jacking point just behind the wheel with a small jack (tyre jack works alright) and then use my big jack to get under the front jacking point when i've got enough clearance
Old 05-01-2011, 06:24 PM   #17
SVR73
Mr Polish
That site says - AU XR6 and XR8 - Live Axle only. Mine is IRS
Why would they put live axle only when all of them are IRS
Old 05-01-2011, 08:08 PM   #18
Dave_Obsession
IIRC the XR6 HP are live axle? Only the XR6 VCT got IRS??
Old 05-01-2011, 08:14 PM   #19
SLO AU XR8
All XR8 Sedans, and VCT engined Falcon Sedans are IRS.
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
