Old 08-01-2011, 01:22 PM   #1
ebxr82nv
Default Xr6 Oil pressure gauge shenanigans
Over the last couple of days my oil pres gauge has been playing up, never going any lower than normal but a couple of times it's been buried well into the red at the top end of the gauge. Nothing else seems to be different while it's doing this so I've got no idea.
Experiences and opinions welcome.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2011, 01:29 PM   #2
sleeper393
sleeper393's Avatar
im having beeping noises that indicate oil pressure , but my oil pressure switch is disconnected . maybe you have a faulty unit , improper earthing or a slight blockage of the pressure switch , unscrew and check to see if any foreign object is obstructing the tiny hole , if nothing time for a new switch . cheers.
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2011, 02:04 PM   #3
ebxr82nv
It's got 300000km so the sender might have given up, I just want some options before I go forking out the coin.
Old 08-01-2011, 03:46 PM   #4
T3man
T3man's Avatar
A bit of oily grime, or a loose connection, will cause a poor electrical connection at the sender which sends the gauge to maximum deflection.
