Old 14-01-2011, 11:01 PM   #1
au adam
au adam's Avatar
Default Running bad in the wet
Hey guys,does anybody else have issues with their cars running crap while driving in the rain?
I have 2 AU 2 utes(ded gas)and they both do it.
While coasting at a certain speed it loses power and i sometimes need to gear down or if i take my foot off for a second and back on again its come good for a few more seconds only.
Any ideas?
au adam is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2011, 11:20 PM   #2
Beer Baron
Does it only do it when its hot or cold as well ?
The air pipe that goes from the snorkel to the converter, Is it getting water down it ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2011, 06:42 PM   #3
au adam
au adam's Avatar
Do you nean hot weather of if the cars temp?
As for the pipe i will check it out.Nice day today and i had no issues.
Old 16-01-2011, 07:51 PM   #4
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Put them back on gas
UK
Old 16-01-2011, 08:03 PM   #5
Beer Baron
Cars temp.
AU XLS.
Old 17-01-2011, 10:37 PM   #6
4ford
The 6 cyl AUs ignition coil pack is positioned right down low in the engine compartment, right down on the front crossmember, left side, below the induction stuff.
I'm thinking these may be getting wet, and maybe the water seals are not properly positioned, hence the bad wet running...just a thought!
This is the best reason I can think of for not driving thru water any more than, say, about 100mm deep, and very slowly, for everyone's benefit!
4ford
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2011, 10:42 PM   #7
Day-mow
rexnet
Day-mow's Avatar
4ford
spot on. if i drive around and go thru a puddle thats to deep (which i try to avoid alot!!) my car starts to miss and sound like a WRX. after a while it dries out.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2011, 12:28 AM   #8
mik
mik's Avatar
do you have factory plug leads on??
Old 18-01-2011, 12:35 AM   #9
au adam
au adam's Avatar
UK
They are both gas only(ded gas)
Old 18-01-2011, 12:35 AM   #10
351@GT
351@GT's Avatar
had similar syptoms in an xh, fine crack in the coil casing, wouldnt kill it, just made it cough for a bit each time it splashed.
351@GT is online now   Reply With Quote Multi-Quote with this Post
Old 18-01-2011, 12:37 AM   #11
au adam
au adam's Avatar
Originally Posted by Beer Baron
Cars temp.
Id say from memory it seems OK when cold,but that could be because i have only just started driving and water hasnt had a chance to reach where ever it goes.
Old 18-01-2011, 12:42 AM   #12
au adam
au adam's Avatar
The auto one has had coil pac and leads recently replaced(last year) and i hanvt had the manual one for all that long so im not sure if it has the original leads.
I was thinking coil pac so when i get the chance i will look at some connections.
As for puddles,i dont think its an issue.The day it got really bad it was very wet and the roads were soaked but i didnt go through big puddles.Thats what i have lifted Patrol for.
Old 18-01-2011, 01:32 PM   #13
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
it just doesent like wet days mate.
weird mine will do the same but its petrol only and going through big puddles which indicates the coil pack.
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2011, 01:49 PM   #14
mik
mik's Avatar
i`m haveing a thought here Adam, if you don`t find another explanation, if it did turn out to be moisture getting into the coil pak from poor sealing leads and rain or a crack in the pak, maybe you could test this by giving the coil pak a bit of a light spray spray with the hose, see if the engine runs the same, drown it in water displacer if it is affected, if its not a problem keep looking else where, or alternatively, carry a tin of wd40 or crc556 water displacer/penetrant in the car , and next rainy day it starts playing up drown the coil pak with one of the previouse products see if it stops the rough running, if it does problem found.
Old 18-01-2011, 05:11 PM   #15
Day-mow
rexnet
Day-mow's Avatar
nope. reg bosch plugs and motor sport leads
Old 18-01-2011, 05:16 PM   #16
Day-mow
rexnet
Day-mow's Avatar
when i sprayed my engine bay out same thing happened.
90% sure its coil pack related
Old 18-01-2011, 05:36 PM   #17
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
G'day all, yeah ive had the same issues in my au 1 futura (petrol only) and i reckon the problem is the loom connecter to the coil and the four connecter pins in the coil connection. The seal there is not very good- once the pins get wet a couple times the connecter pins start oxidising and go green. The fix i did was to clean both the pins and loom connecter (scrape the green crap off or use contact cleaner), spray both sides with a heap of wd40 or crc, refit connecter to the coil and tape up the connection with plumbers tape or if you want to get fancy fabricate a water deflector to deflect water away from the coil. Since i did the fix i havent had the problems with the engine missing and carrying on in the wet but i still try to avoid the big puddles!
cheers Maka
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2011, 10:25 PM   #18
au adam
au adam's Avatar
Thanks guys,have been a great help.
