Old 13-01-2011, 01:51 PM   #1
prasac
prasac's Avatar
Default Video of PROFAB 370ci Twin Turbo V8 Ford Cortina MSB No. 1
video of Joe Gauci's twin 70mm turbo 370ci SBF. this car is currently number 1 in APSA Modified Street Blown running a 7.45@194 yeah a mid 7 on a factory style suspension. engine is a Proline engine assembled by Dandy Engines, tuned by Steve Petty from ProLine and currently makes around 1800hp.
Joe Gauci Twin Turbo V8 7-sec Ford Cortina video
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2011, 02:00 PM   #2
GEE-347
CRUzn
GEE-347's Avatar
HOLLY F*%#!!!! uuuuuuunbelievable!!!!! Well done & great job Joe congrats to him & everyone involved with this car!
GEE-347 :
T Series Club Australia
Special Thanks to
Brett & Zoran @ BnZ Automotive & Dyno
(347ci Windsor) 440bhp pump fuel
363ci Windsor in the Build
GEE-347 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2011, 02:40 PM   #3
prasac
prasac's Avatar
thieved these off another site, have pics just got to go thru. camera had a bit of a stuff-up
Old 13-01-2011, 08:09 PM   #4
63futura
63futura's Avatar
More info
Car looks awesome
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2011, 11:37 PM   #5
prasac
prasac's Avatar
chassis built by Joe, runs 2 Precision 70mm turbo's, water/ice intercooler, runs on Roo16. 60's 1.29-1.30 i think Joe was saying he was looking at some bigger turbo's in the future as these ones are almost on the limit. this thing is an absolute weapon i'm sure it will be doing 200mph passes very soon, it's only a very new combo, i don't think it has done more than 10-15 passes.
Old 14-01-2011, 12:11 AM   #6
mickyyyy
what deck size block is he using???
8.2, 9.2 or 9.5???
He also does great fab work and rear ends
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2011, 09:25 AM   #7
prasac
prasac's Avatar
8.2, 9.2 or 9.5???
i think, but im not 100% sure it's 8.2 my mate was talking to Joe also he said he has the exact same block as him and he runs an 8.2
Old 14-01-2011, 01:29 PM   #8
futura
futura's Avatar
Thats one tuff corty! love cortinas
Old 14-01-2011, 03:14 PM   #9
prasac
prasac's Avatar
the Corty's have a great *** end setup to go fast numbers. PSIDUP went a 7.39@179 recently with a bigger turbo combo.
Old 14-01-2011, 04:47 PM   #10
futura
futura's Avatar
Amazing times from such a little rear tyre size. Once C&V get a handle on the setup, PSIDEUP should be running low 7's or even high 6's are possible!! Remind me of the good old days with WOG007.
Old 19-01-2011, 08:39 AM   #11
prasac
prasac's Avatar
it is crazy, factory style suspension cars running that quick. the thing is with the MSB cars are that they are limited to twin 70mm turbo's or a single 95mm both are capable of pushing out around 16-1800hp. so the times may not come down much more, unless they can find a few chassis tweaks or take some weight out. PSIDUP is very fortunate to have the likes of Burnsy helping him set the car up, he is one of the best in Australia.
the nitrous boys are coming i know alot of them are looking at bigger cubes and bigger shots of NOS, Johnny Habib has a new engine on the way, and the Staunch Racing boys have something up their sleeves also. i'd love to see Stu Henry come out and post a quicker time for us Capri boys
it's funny to see 4 of the 5 Ford's in the Top 15 are turbo cars, only Holden turbo is the Jake Edwards Torana.
1. Joe Gauci 370ci TT Cortina 7.45@194
3. Stu Henry 420ci T Capri 7.68@183
4. PSIDUP 417ci TT Cortina 7.75@185
11. Joe Geri 240ci TT Capri 8.34@165
Old 19-01-2011, 09:50 AM   #12
mickyyyy
So u saying it still has the shock's on an angle just like factory???
Old 19-01-2011, 01:46 PM   #13
prasac
prasac's Avatar
shocks and leaf-springs can be moved. here is a list of the rules. they are also on the APSA website http://www.austprostassc.com.au/home.shtml
FRAME / CHASSIS
1.1 Front suspensions can be fabricated but must bolt into stock location, fabricated tube control arms and K members permitted, stock front cross members may be scalloped for sump clearance. RRS front suspension is permitted for Falcons and Mustangs. In American bodied vehicles (originally LHD) substitution of local front end of similar design to standard is permitted, i.e. Holden HQ-WB front end in “55-57” Chevrolet. Steering rack conversions permitted.
APSA would like to ensure that all front suspension components are built with safety as paramount in all cases.
ANDRA safety rules apply to all cars.
1.2 Firewall must remain in standard position. Notching for distributor or rocker cover clearance only is permitted. Flat firewalls are permitted but must be in standard location. Chassis rails in engine bays may be chambered to a cross section of 60mm x 60mm or an area equaling to this amount to allow exhaust clearance. All material removed from chassis rails must be replaced with the same thickness material or thicker. This may also be the case for cars needing to notch strut towers in engine bays for pipe clearance. Chassis rails must be in standard location.
1.3 Front struts may be replaced; aftermarket products must bolt up in the factory position.
1.4 Inner rear wheel tubs may be moved inwards, full tub replacement permitted. Chassis connectors are permitted.
1.5 Standard rear suspension points must be used, rear suspension mounts maybe reinforced or fabricated in standard size, shock absorber location can be moved, and leaf springs can be moved inwards.
1.6 Coil over shocks are permitted for tyre clearance.
1.7 Rear chassis rails may be notched for tyre clearance but not moved or rerouted. Inner chassis rail cannot be moved and must remain in factory position. Any metal cut away must be replaced with the same thickness material or thicker. Special permission may be given to existing cars with rails moved if standard points are retained and tyre is within the limits, but must be checked with APSA committee.
1.8 Four links and ladder bars are not permitted.
1.9 Adjustable tubular control arms may be used on rear ends but must retain factory fixed mounting points and suspension set up. Tramp rods, Slapper bars, Caltrac bars or any other similar devices may be used. Anti roll or sway bars permitted.
1.10 Fiberglass panels are restricted to guards, nose cone, bonnet, boot lids and bumpers.
1.11 Lexan /polycarbonate windows permitted all round as per ANDRA specifications.
1.12 Must have some style of dash, original dash board may be replaced by a fabricated dash.
ENGINES
2.1 Engine blocks,
Small blocks cast iron only with standard cam and standard pan rail, max deck heights SBC 9.025, SBF 9.5, Chrys SB 9.5, Holden 8.9, LS-1 9.2, Mod motor Ford 9.0,
Factory alloy blocks permitted, eg. LS-1
Big Blocks cast iron only with standard cam and pan rail BBC 10.2, BBF 10.32, Chrys BB 10.7
Any other combinations must be standard deck height.
2.2 Maximum head gasket thickness .150"
2.3 Dry sumps are not permitted.
2.4 Transmissions must be OEM type, No Lenco’s or aftermarket clutch less type, lock up convertors are permitted, Dedenbear cases are permitted
WHEELS AND TYRES
3.1 Maximum diameter 15”
3.2 Maximum tyre width and height 29.5”x 12.5” as marked on side wall and in measurement, no "w" tyres permitted on max size.
3.3 Front tyres must be a minimum width of 3.5”
SUPERCHARGERS / TURBO CHARGERS / NITROUS OXIDE
4.1 Roots type superchargers are as per Pro Street Blown but are restricted to 10:71
4.2 Turbochargers are as per Pro Street Blown but are restricted to a maximum size of 94mm inducer diameter (tip-to-tip) for single turbochargers and 70mm inducer (tip-to-tip) for twin turbochargers at the point where the edge of the compressor wheel meets the inlet housing and must be of conventional impeller and housing design (non-clipped).
4.3 Single centrifugal superchargers are permitted with a maximum inlet hose diameter of 6.00in and maximum discharge hose diameter of 4.00in (e.g. Procharger F-3R-131).
4.4 Nitrous Oxide systems are restricted to a single stage. Fogger or plate systems permitted. If using direct port systems, a maximum of two nitrous solenoids, two fuel solenoids and two purge solenoids allowed. If using plate system, one nitrous, one fuel and one purge solenoid allowed. Nitrous controllers are permitted
MINIMUM WEIGHTS including driver
MSB Big block 2800lbs
MSB Small block 2650lbs
MSB 4 and 6 cyl 2500
