With da Warlords
Hi All.
Lent my car to my old man on the weekend. Anyway I noticed this morning when reversing out of the garage, that the steering wheel is making a clicking noise when turning. I suspect it could be the clockspring (and I have had intermittant faults with my airbag light lately too). Does this sound right? and what is involved in replacing it... Cheers.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 ![]() ![]() XR50T Ute - 300rwkw (give or take depending on the day)
Flairs - Truckers Delight
clockspring is fairly easy to replace - just need to take the airbag off iirc?
also check it's not just your cowling around your steering column...
#3 | |||
BOSS Pilot
Mine has recently started clicking aswell in my Ba xr8. If I move the wheel barely to one side it will click and then click again on the way back. If its a similar setup to the BAs they are pretty easy to get apart just pull the airbag and steering wheel off and thats about the bulk of it. I had mine off about 6months ago and it was fine when I put it back together and then started clicking only about 2months ago
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
