Old 20-02-2011, 04:38 PM   #1
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Electric Seat help
So i've got GSAU's old Ghiasaurus, which has a broken drivers seat
it will only go forward/backwards on the right side rail, which means it pretty much doesn't go anywhere. The issues is that there is a little drive rod that goes from the electric motor to the part that moves the seat rail, and it has completely broken off. It looks like this:
What should I do? Is this a problem that can be repaired? Or do I need to replace the whole seat base? If so, can I just get a regular manual seat base instead?
Old 21-02-2011, 11:54 PM   #2
Mr Hardware
Must just be one of those 'if mr hardware doesn't know, then no-one knows' kinda things.
Old 26-02-2011, 03:56 PM   #3
Ride
Stay Classy ™
Ride's Avatar
You can replace it with a regular manual seat base, but from memory the motor only drives one side and the other just follows? Is there anything jamming the left hand side from moving?
Ride is offline   Reply With Quote Multi-Quote with this Post
