Old 17-03-2011, 06:31 PM   #1
Franco Cozzo
Franco Cozzo's Avatar
Default Driving lights from USA
Hey guys, I'm looking at buying a set of driving lamps, they tend to be a lot cheaper from the USA, would those be the same as ours or would they be pointed the other way?
Thanks much.
Old 17-03-2011, 06:33 PM   #2
Smoke Pursuit
Default Re: Driving lights from USA
Driving lamps?? what sort..
As in highbeam spot lights?? They arent dipped in any direction as they are to run on highbeam...
Or are you talking about foglamps??
Big difference. Whatever you buy make sure it has an E stamp...
Old 17-03-2011, 06:41 PM   #3
Franco Cozzo
Similar to highbeam spot lights, except they're "spread beam", wide rather than long. Only used with highbems.
Old 17-03-2011, 06:41 PM   #4
Jim Goose
Driving lights for his XC im guessing...
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2011, 07:05 PM   #5
Franco Cozzo
XC? I have a LV Focus, lol.
Old 17-03-2011, 09:36 PM   #6
Jim Goose
Oops sorry thinking of the wrong person!!! argh.. XCwilo...
Old 17-03-2011, 09:40 PM   #7
JC
Miami Pilot
JC's Avatar
Thanks much.
Well, seeing as they are for left hand drive cars, you'd probably need to mount the LH one on the drivers side, and the RH on the passenger side and you should be right. And if you're not joking with your question, I'm not joking with the reply either.
Ford Performance Club ACT
Old 18-03-2011, 06:18 AM   #8
midnightXR6
Im having this problem with a ba xr6. Im taking it to germany and obviously by law i have to get a headlight beam bender sticker to change the beam direction.
Only problem is no on e knows where it should be placed for it to work.
midnightXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2011, 09:55 AM   #9
Mesa
Would a polariser sticker on the back window work???
Mesa is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2011, 04:58 PM   #10
MO
MO's Avatar
If the glass lens has no pattern stamped in it you will be ok however if there is a pattern forget it.
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2011, 05:07 PM   #11
Franco Cozzo
I was thinking they are aimed in the opposite direction like headlights, I'm going to givei t a miss to be safe and just shell out the few extra hundred.
Old 18-03-2011, 05:15 PM   #12
MO
MO's Avatar
Way to go,better safe than sorry.
FORD RULES OK
