Old 22-10-2005, 08:17 PM   #1
falcon_I6
Default Missing?
Hi all, i have an EA 5spd multi point, the car has just started to develope a miss, i have no idea what it is, it sounds like a popping noise, as if the zorst was leaking, but i have checked all that out and there is no such leak.
Could it be the O2 sensor being on the way out?
Please help. I have no idea what to look for. Thank you
Old 22-10-2005, 08:20 PM   #2
BlOWN-EA
BlOWN-EA's Avatar
answer these questions:
does it miss at idle
does the miss go on accel
does it flat spot
No. Of Snapped Axles So Far: 2
BlOWN-EA is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2005, 08:22 PM   #3
falcon_I6
miss on idle. yes
does miss go on accel. yes
does it flat spot. no
Sorry i should made my post clearer.
Thanks
Old 22-10-2005, 08:29 PM   #4
BlOWN-EA
BlOWN-EA's Avatar
does idle fluctuate or does the engine just run rough
first of all grab your self a can of carbie clean start up your engine,
let it idle and spray all along the inlet manifold gasket if the idle dies or drops when you spray it you got a inlet manifold leak, can use that to find other vacumm leaks, check map sensor vac line.
the fact that you said it goes on accel, but missfires at idle and you hear a pop noise from exhasut reguarly at idle, you may have burnt valves, carry out running compression test, and compare cylinder pressures they shouldnt be too far apart for example:
Example 1
acceptable:
Cyl. 1 - 185
Cyl. 2 - 190
Cyl. 3 - 180
Cyl. 4 - 185
Cyl. 5 - 195
Cyl. 6 - 175
Example 2
not acceptable:
Cyl. 1 - 185
Cyl. 2 - 120
Cyl. 3 - 180
Cyl. 4 - 185
Cyl. 5 - 195
Cyl. 6 - 150
Old 22-10-2005, 09:05 PM   #5
XR Martin
XR Martin's Avatar
Checked spark plugs, leads, dizzy cap and rotor?
2004 BA wagon RTV project.
Old 22-10-2005, 09:39 PM   #6
falcon_I6
Dizzy is pritty much brand new, umm, i think i might check all the vacume lines, so you dont think it could be O2 sensor? cheers
Old 22-10-2005, 10:09 PM   #7
falcon_I6
There was a green vacume wire coming out of the fire wall, connectiong to a goldy coldered thing, like a round something not sure what it is, could that be the problem?
Old 23-10-2005, 12:29 AM   #8
XR Martin
XR Martin's Avatar
No thats the heater tap.
Old 23-10-2005, 08:09 AM   #9
falcon_I6
So thats not a vacume line?-bummer
Old 23-10-2005, 11:25 AM   #10
XR Martin
XR Martin's Avatar
It is a vacuum line, but it wont make a difference on how the car runs.
Old 23-10-2005, 03:55 PM   #11
falcon_I6
Okay, now it is really bad, near undrivable. the further u drive it, the worse it gets, was going for about half an hour, and it is just constant miss, but when you rev it out a bit more, it will stop until you are doing normal revs again.. I got no idea
It also is now developing flat spots..
Old 23-10-2005, 07:16 PM   #12
JUZXR8
Hmmmmm
JUZXR8's Avatar
sounds to me that you need to check out your spark plugs and leads
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2005, 08:58 PM   #13
falcon_I6
Yer, i need to by plugs, i have a set of 8mm leads here that are new, i unplugged my O2 sensor wen it was missing, and nothin at all changed, mite grab one of them to...
Just gota find some time to go get it all...
Could it be anything else? Cheers
Old 23-10-2005, 09:44 PM   #14
BlOWN-EA
BlOWN-EA's Avatar
have u done anything of wat i said, swapping parts till u get it right doesnt work to well just carry out the apropriote tests to find wat the prob is, remember measure twice cut once
Old 24-10-2005, 12:42 AM   #15
XR Martin
XR Martin's Avatar
I dont think it will miss with a bung O2 sensor, just run hell rich.
Could also try the Map sensor hose. The Map sensor is under the top of the firewall near the main loom of wires, just above the heater hoses. Check the hose that connects to it for cracks or splits.
Old 24-10-2005, 06:39 AM   #16
falcon_I6
Well, i have sprayed carby cleaner around everywher, like around all the vacume hoeses, nothing. i'l just change the plugs and leads, havnt had time to do a compression test, but if it was in the head or "mechanical" wouldnt it do it all the time? cause when the car is cold it is beautiful. only after it heats up is when it turns to the bad side.... lol.
Thank you all for help
Old 24-10-2005, 09:03 PM   #17
falcon_I6
It stoped for me in the shed 2nite, after a few hours of fault finding, it was the coil... It lot easier to find when completly stoped... Should have part in and going by tomorrow hopefully... fingers crosts i can get a coil tomorrow
