Old 15-05-2010, 11:00 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default Manual Exploded view
i need an exploded view for the manual in my car.
its changer is kinda sloppy and i think its a bush or something thats worn out.
also. excuse my dumbness. its a T5 manual yes?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2010, 11:10 PM   #2
frd906
yes its a t5 manual
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 02:13 PM   #3
mik
mik's Avatar
i had a bit of a look in a transmission book for a t5 diagram was`nt much there, , but its a common tranny used by ford gm,jeep etc, there are snippets on google , look up borg warner t5 i think , you might find something, there is a couple of pages of a rebuild magazine in a ford mag unless your a subscriber you get the first 2 pages only theres a little bit of the shifter........click on the smaller pics
http://www.google.com.au/imgres?imgu...N46TkAW62uzjBw
Old 16-05-2010, 02:29 PM   #4
Day-mow
rexnet
Day-mow's Avatar
thanks guys. basically i just want to pull the gear leaver off from the top and hope that there is bush i can acess from the top and replace to fix the sloppiness. not made keen on dropping the trans for a grommit
Old 16-05-2010, 02:46 PM   #5
frd906
should put a short shifter in if u havent already done so
Old 16-05-2010, 02:51 PM   #6
bartsau
bartsau's Avatar
Well i can tell you there is a bush in there and the shifter has lots of slop when it is buggered. Here are some pics of the buggered bush.
I had this gearbox and the one now in my car next to each other a while ago and this bush is definately the reason.
Cheers, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 03:09 PM   #7
Day-mow
rexnet
Day-mow's Avatar
A. what does a short shift actually do (yes im dumb)
B thanks so much rhys. guess its a gear box out job then?
Old 16-05-2010, 03:11 PM   #8
frd906
Makes the shift between 2nd and 3rd alot easier,
Old 16-05-2010, 03:23 PM   #9
bartsau
bartsau's Avatar
Pretty sure it would be easier with the box out but it may be able to be done by simply removing the centre console. Then just support the rear of the box and lower it slowly by removing the rear cross brace from underneath. This may give you enough room to get through from the top to do it. However without having tried this i can't be too sure.
As for a short shifter effectively it shortens the throw between all gears and with a better return spring enable more 'Positive' shifts between gears. This would be most noticeable through the 2-3 shift as this is the worst out of them to start with. However, i have never actually used one so someone who has will be able to tell you more accurately if it is worth it.
A short shifter replaces the top section which unbolts. It also includes the section on the very left of picture 2. This is the mechanism that allows (through different angles) to give it a shorter throw.
Cheers, Rhys
Wagon Build
Toy Car Build
Old 16-05-2010, 04:56 PM   #10
mik
mik's Avatar
i think i`d rather drop the x member and remove the console than pull the box out if neccassary than pull the box out , does any one have a pic of an au gearbox/tranny tunnel without the console carpet etc?
Old 16-05-2010, 05:29 PM   #11
bartsau
bartsau's Avatar
I will go take one now! Give us a couple of mins
Ok this is it. First photo is with the gear lever and surround. This can be removed by taking off the gear lever and then from underneath there are 4 nuts holding the white plastic thing on.
Then this is what it will look like
Cheers, Rhys
Wagon Build
Toy Car Build
Old 21-05-2010, 08:11 PM   #12
Day-mow
rexnet
Day-mow's Avatar
im thinking droping the box will be easier. and i can kinda get to a hoist easily. it just wont happen for a while
Old 21-05-2010, 08:29 PM   #13
bartsau
bartsau's Avatar
Good luck with it when you do it. Let us know how it goes to...
Cheers, Rhys
Wagon Build
Toy Car Build
Old 20-07-2011, 08:28 PM   #14
xr6_boss
Default Re: Manual Exploded view
Hey guys i had the same problem with mine but the part i got is only the plastic bush where the one that was in there had a rubber coat over it over it just wondering if its a seperaye piece or what to do ???
BLACK AU II MANUAL XR6 UTE
2.5 inch Redback Exhaust
Pioneer 6050 2 din unit
Pacemaker 4499s
Custom CAI
xr6_boss is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2011, 08:45 PM   #15
bartsau
bartsau's Avatar
The rubber section is part of the shifter block itself as it is molded into it. This from ford is worth about $160 from memory whereas the plastic bush is the only separate part you can change apart from the block and the plastic bit is worth about $23??
Hope this helps.
Cheers, Rhys
Wagon Build
Toy Car Build
Old 20-07-2011, 08:49 PM   #16
xr6_boss
Ohh okk well when i pulled out the bush the rubber was pretty stuck to the bush itself .. The rubber didnt stay in the block .. Could i just fiill around the bush with some sort of silicone application?? The bush fits in well without the rubner ..
Pacemaker 4499s
Custom CAI
Old 20-07-2011, 08:56 PM   #17
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
http://www.youtube.com/watch?v=5VHU6eHDPrE
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2011, 09:23 PM   #18
bartsau
bartsau's Avatar
Not too sure if you can get away with that? I will be pulling mine apart tomorrow so I will have another look as it is a while since I have had a good look at it.
Also, I know you can order from the US brass bushes to replace the plastic ones. However, they apparently transmit more vibration and I would think would wear the rubber out quicker.
Wagon Build
Toy Car Build
Old 20-07-2011, 09:28 PM   #19
xr6_boss
Well the rubber is stuck to the other plastic bush which has broken in half.. Could pull it off the original bush but dont no if thatll work ..
Pacemaker 4499s
Custom CAI
Old 20-07-2011, 09:28 PM   #20
xr6_boss
Pacemaker 4499s
Custom CAI
Old 20-07-2011, 10:23 PM   #21
Day-mow
rexnet
Day-mow's Avatar
5/8th heater hose is holding mine firm at the mo. Hahaha
Old 21-07-2011, 08:06 AM   #22
xr6_boss
Yeh ? How long have yu had it in there ? Might give that a go ...
Pacemaker 4499s
Custom CAI
Old 21-07-2011, 10:20 AM   #23
Day-mow
rexnet
Day-mow's Avatar
Ahhh. September. Only because I needed my car back togetherthat day and I didn't have the$$$ to get the replacement.
It's starting to get loose I'd suggest doing it right.
Old 21-07-2011, 10:54 AM   #24
xr6_boss
Yeh .. So whats the part i need to order to fix it properlly ..? Whats it actually called ? Ha
Pacemaker 4499s
Custom CAI
Old 21-07-2011, 11:45 AM   #25
xr6_boss
Was reading around and see some people say yu can leave the rubber bush out and it will feel firnmer should i give this a go ???
Pacemaker 4499s
Custom CAI
Old 21-07-2011, 07:56 PM   #26
bartsau
bartsau's Avatar
While I had a look at it tonight and have come to the conclusion that there is no way the plastic bush is coming out without damaging the rubber as they have become one over time and use. Not entirely sure how I am meant to use the plastic bush I have now though :/
Wagon Build
Toy Car Build
Old 21-07-2011, 08:12 PM   #27
Day-mow
rexnet
Day-mow's Avatar
correct. so you have to put the 5/8th hose (or actually replace the whole part) inside the gear box and then you put the plastic bush in on the shifter
Old 22-07-2011, 10:08 AM   #28
xr6_boss
fixed mine up this morning with 5/8 heater hose and some glue. feels amazing to what it did. lets just hope it lasts !!
Pacemaker 4499s
Custom CAI
