16-08-2011, 08:42 AM | #1 | ||
Hi guys and gals I have a ford Mondeo 97 2.0 lt auto Ztec engine with a few dramas first the gearbox wont change up as if the modulater valve is not working(if it has one) and the governer makes it change up.
Also need a timing belt marks diagram And the radio keeps coming up error and wont let me put code in Any help greatly appreciated Thanks |
16-08-2011, 08:20 PM | #2 | ||
Definitely check the DC power connection to your radio . . . look for anything that would make the connection intermittent (connector/s not plugged-in properly, loose fuses, etc). Sounds like power is being applied and lost many times.
Can't verify the source accuracy of this doc so please check: Page 2 has the timing markers; [CODE]http://www.fileserve.com/file/Q4YwNNG/Mondeo_timing_belt.pdf [/CODE] Can't help at all with the auto . . . Good luck, |
