Old 30-08-2011, 05:00 PM   #1
squizzy28
Ford For Life
squizzy28's Avatar
Default ABS playing up
been a while since i've been on here but need some help with my parents AU 3 fairmont. They recently got new tires, pads and rotors put on and ever since then the abs has been randomly kicking in. it only happens occasionally 3-4 times a drive but it happens in weird spots like stopping at a traffic light or pulling in to a drive way. no hard braking. it feels like the drivers side front and you can feel it through the brake pedal and hear it. no lights come on the dash and our mechanic has but it on his diagnostic computer and no errors come up and he can't figure out what it is. he tried to fix it by again changing the brake pad and rotor and cleaned the sensor but made no difference. anyone have any ideas??
2003 Fairmont Ghia-Mercury Silver
Has:
For looks: SR Body Kit, 18in XR8 wheels, Fairlane dash and clock(red backlight), Red LED's in footwells, Black ICC facia, FPV pedels and steering wheel,Orange New GT style strips with Ghia in them, Orange calipers to match, Spoiler, Altezza Taillights
For Go: Larger upper and lower air inatke, pod filter with 3" intake, pacemaker 4490's, 2.5" magnaflow cat with custom 2.5" exhaust.
squizzy28 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 06:09 PM   #2
Beer Baron
Default Re: ABS playing up
Did he clean the toothed wheel on the hub and axles too ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 07:30 PM   #3
EATHSV
Oo---oO
EATHSV's Avatar
keen to hear some wisdom on this also. My partners futura is doing EXACTLY the same thing.
AU2 Fairmont Ghia - Monsoon Blue, TS50 wheels -ongoing project.
Successful transactions with the following members:
Ride, Raised by Monkeys, TICK4D-TAS, Falcman007, 2002AU, JC.
EATHSV is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 08:41 PM   #4
FGII-XR6
FGII-XR6's Avatar
we had this with a cab a while back and it was actually the Diff the movement in the axle was causing the ABS to pulse . It took a while to work out but a diff specialist told us it is common in a live axle falcon
[SIGPIC][/SIGPIC]
Rides:
Old 30-08-2011, 11:35 PM   #5
squizzy28
Ford For Life
squizzy28's Avatar
can you explain more about what the diff problem was if you can so when they take it to someone they can tell them.
Has:
Old 30-08-2011, 11:40 PM   #6
EATHSV
Oo---oO
EATHSV's Avatar
This makes sense to me as her diff has a bit of play where the driveshaft attaches so it clunks a bit when starting and stopping. Just need some more green stuff to fix that.
Old 31-08-2011, 08:33 AM   #7
bartsau
bartsau's Avatar
The last month or so I have had the exact same problem with my wagon. Although I am sure this is due to the 9" diff in the back having screwed around with the abs somehow. Sometimes it gets so bad that the light comes on indicating the abs is not active anymore. I can turn it off and on again and everything goes back to normal. Weird...I was wondering if the diff bloke didn't damage one of my sensors? Or if the toothed wheel is not sitting quiet right with the sensor? Or some movement of the axle? Although I really hope it is not the axle moving around.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
Old 31-08-2011, 10:07 AM   #8
FGII-XR6
FGII-XR6's Avatar
the pinion bearings were flogged out and allowing the axles to move funny thing is it wasn't noisy but we saw the diff when he pulled apart and I'm surprised it hadn't self destructed long before this. cars can be strange things at times
[SIGPIC][/SIGPIC]
Rides:
