Old 31-08-2011, 05:05 PM   #1
zakjames
zakjames's Avatar
Default Please help - A/C + torque concern
AU series 1 sedan XR6 VCT Manual
Hey all, on Monday I filled up with Shell V-Power for the first time on an empty tank (I usually use BP Ultimate but decided to see what V-Power was like)
And today especially I noticed a large decrease in torque that I normally feel, particularly around the 3000rpm mark, could this be a hand in hand fault with the different fuel used?
Also for a short while now (Say about 3months) whenever I turn my A/C on it makes a quiet whining noise from the engine bay and increases with engine rpm. At first I didn't think much of it (it was ALOT quieter when it first started happening and shrugged it off as normal operation) but now it is getting slightly louder and since it has started my A/C has been getting less and less cold.
I'm thinking theres a concern with the compressor and maybe a leak somewhere in the system but just wanted to check with you guys if there is any common problem known with these?
Thanks all and any help or advise on either concern if greatly appreciated.
zakjames is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2011, 06:49 PM   #2
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
Default Re: Please help - A/C + torque concern
V-power is crap. If I get stuck and have to use it, I get woeful fuel economy in my XR, and the same goes for my wife's Kluger. Nothing but Ultimate for me. As for your ac, low on gas for sure, get right onto it before the seals dry out.
-Craig
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2011, 07:11 PM   #3
zakjames
zakjames's Avatar
Cheers man, so you reckon the comp. is all good then? will do an A/C gas sniffer test tomorrow to check leaks.
Old 31-08-2011, 10:19 PM   #4
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
I wonder if resetting the ecu would help it learn the v-power quicker -its been used to the ultimate, then all of a sudden you've changed fuel.
AMB is offline   Reply With Quote Multi-Quote with this Post
