Old 03-08-2011, 10:44 AM   #31
DZFord
DZFord's Avatar
Default Re: Headers & exhaust fitted
Originally Posted by focus36
Which a couple of mechanics have told me will stuff up amounts of fuel been injected, therefore not having the most efficient/powerful result...?? Apparently pacemaker now make a type of "false" sensor to get around this issue of extra emissions been detected post cat..
You can remedy the fuel / air mixtures with a custom tune. In Vic, Bullet Performance Racing do them for the Focus.
The check engine light (CEL) comes on due to an error code - usually a "P0420 - Catalytic Converter Efficiency Below Threshold" - basically saying that exhaust emissions are above normal (ie. due to a more efficient header + high-flow cat). The code itself is just an emissions warning. It is not a warning regarding altered air/fuel mixtures. If a cylinder(s) is running overly rich / lean, seperate error codes exist for this.
There are 3 ways to address the CEL:
1. Fit an 02 cheater harness / sensor as you have described
2. A custom tune can also turn off the rear exhaust stream 02 sensor (ie. the sensor after the cat)
3. A spark plug non-fouler trick, as I have done - yes, believe it or not, this really works (it is a mechanical fix, not an electrical / computer fix): http://www.fordforums.com.au/showthread.php?t=11251960
Here is the how-to: http://forums.evolutionm.net/evo-how...ouler-how.html
Old 03-08-2011, 10:54 AM   #32
DZFord
DZFord's Avatar
By the way, if you fit the xforce system, I would recommend this change to the rear muffler (unless you love drone!)
http://www.fordforums.com.au/showthread.php?t=11299664
Post #8 in the thread above also has more info RE: anti-fouler fixes
Old 14-08-2011, 03:28 PM   #33
focus36
focus36's Avatar
Ok, so you are saying that i should only get a warning light regarding emissions, and it wont actually be altering air/fuel mixtures? If this is the case then no problem. That way i can hold out on getting it retuned when i have head work done on the engine.
Getting the x-force system put on tomorrow, with an extra resonator at the back, (heard enough drone in my life!) so hopefully all goes well.
Thanks again DZ
focus36 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2011, 07:24 PM   #34
DZFord
DZFord's Avatar
The new header and cat will definitely cause a change in air-fuel ratio. Your ECU has some ability to compensate / adjust for this, but it will never be 100% optimal unless it is custom tuned.
Otherwise, yes, the warning light is due to emissions only.
Good luck with the install!
PS - pics or ban!
Old 14-08-2011, 10:14 PM   #35
focus36
focus36's Avatar
Haha. No worries
Just checking that it wouldn't put the ecu into a "limp home" mode.
Old 16-08-2011, 11:27 PM   #36
focus36
focus36's Avatar
Well, X-Force forget to package the main muffler with everything else. doh! So yesterday i had header, cat, and mid section pipe/resonator installed and just temporarily linked to the standard rear muffler and pipe - So it's quite a bit quieter than it will be in the end. But most of the way there at least
The pacemaker post cat sensor cheater seems to do it's job, no engine lights at all !! very happy with that.
Here is the header - exactly the same as DZ's
Join of old and new
Mid section with nice shiny resonator.
Hopefully the rest of the system turns up soon and it will be finished properly.
Old 17-08-2011, 10:01 AM   #37
DZFord
DZFord's Avatar
Great stuff, I love the look of shiny new headers.
Can't believe they forgot the main muffler. When will you have it finished off?
Old 17-08-2011, 04:10 PM   #38
focus36
focus36's Avatar
Won't be till next week now :(
Abs light came on in the car this morning... hmm, couple of days after exhaust so shouldnt be related..
Old 17-08-2011, 06:14 PM   #39
DZFord
DZFord's Avatar
If you do a search in this section of the forum I think there is some info on the ABS light, I remember some members having trouble with it in the past.
Old 17-08-2011, 06:39 PM   #40
marg99
First thing to check when the ABS light comes on is the amount of movement in the wheel bearings. The ABS system has trouble picking up messages from the wheel hubs if the bearings collapse as it throws the distance between the hub unit and the sensor out.
Put car up on a jack and with both hands wobble the wheel up and down. It should have virtually no movement.
Old 14-09-2011, 11:23 AM   #41
focus36
focus36's Avatar
Ok cheers. Will do this at some stage. Hopefully I don't need new hubs! I have no noise associated with a bad hub, so hope not. Could it just be dirty sensors if thats the case? The abs light spends most of the time off. Quite often makes an appearance though...
Old 14-09-2011, 05:25 PM   #42
focus36
focus36's Avatar
http://www.fordforums.com.au/showthread.php?t=11342997
link to my headers/intake thread
