Old 14-10-2011, 01:44 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default front brake lines - what tool to undo?
Changing my brakes over in the next few weeks and I am wondering what tool I will need to undo the brake lines? I struck trouble when trying once before and didnt want to break it.
2024 F150 XLT
Old 14-10-2011, 02:03 PM   #2
fat4D
Default Re: front brake lines - what tool to undo?
if its the end where the flexible hose connects to the metal line there is a cir clip which a small flat head can be used to pop out a bit then pointy nose pliers to pull off
Now Ford-less
But good things are coming in 6 months
fat4D is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 04:16 PM   #3
blownv8au
Pro Street Au Ute
blownv8au's Avatar
If you are refering to the joint between the hard line a flexi line, i use a high quality pair of vice grips and clamp them on real tight, flat on flat ie front of the grips on the flat sides of the nut, just use them to crack it . pull the clip out after undoing the nut. I've tried spanners over the years and they usually strip and you end up using vice grips anyway,
Old 14-10-2011, 11:38 PM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
10mm 6 point crow's foot spanner, followed by vice grips if it strips
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2011, 12:51 PM   #5
Beer Baron
That or a decent set of pipe spanners. using vice grips 1st up is stupid as vice grips leave teeth marks and makes it hard to get any spanner on ever again.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2011, 12:56 PM   #6
buggerlugs
If it ain't broke........
If your not doing it for a couple of weeks spray some lanolin on them now.......
Visitors welcome
Relatives by appointment only
buggerlugs is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2011, 01:01 PM   #7
mik
mik's Avatar
pipe spanner
Old 15-10-2011, 01:22 PM   #8
mongrelEF
Bugger!
mongrelEF's Avatar
Crow's foot spanner = pipe spanner
Old 15-10-2011, 03:40 PM   #9
b2tf
b2tf's Avatar
Pipe spanners look to be the go. Trip to Bunnings next weekend I reckon.
2024 F150 XLT
Old 15-10-2011, 03:44 PM   #10
Ford Falcon XR6
Ford Falcon XR6's Avatar
I've used pipe spanners on mine i they only slipped and stripped the nut used Crow's foot spanners and they were the way to go
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2011, 05:41 PM   #11
Beer Baron
Haven't heard them called that before so I wasn't sure. ;)
Right tool for the right job + common sense and there is no problem.
AU XLS.
Old 15-10-2011, 05:50 PM   #12
T3-TS50
T3-TS50's Avatar
This is the one Austin,use a 3/8th drive ratchet on it,used it on my AU
Pipe spanner just spun off.
Pack of six differant sizes Repco about $10
T3 Hardcore
T3-TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2011, 11:33 AM   #13
RG
Back to Le Frenchy
RG's Avatar
Autobarn/Bursons/Repco for this one over Bunnings mate.
Old 17-10-2011, 06:44 PM   #14
DW260
DW260's Avatar
I've got a set of these, Aust - I'll bring them back for you next weekend.
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2011, 06:44 PM   #15
b2tf
b2tf's Avatar
Thanks - can you bring the other stuff too?
2024 F150 XLT
Old 17-10-2011, 07:49 PM   #16
DW260
DW260's Avatar
Yes. Yes I can.
Old 17-10-2011, 07:57 PM   #17
atec77
Originally Posted by mik
pipe spanner
This
$35.00 from supa cheap for a set
