10-10-2011, 11:07 PM | #1 | ||
Ok, passenger side regulator was stuffed, drivers side was slow, brought 2 off ebay, 125 posted and fitted them up last week, passenger side is perfect now, drivers side is going up to 3/4 and window against pillar is moving out on angle, it did this but not like this beforehand, i notived on where you clip the top of regulator in that the opaque colored clip was bent and the new plastic upper clip wasnt secure, to stop this i heated up the clip and formed it back straight, greased track and cleaned it out, still cant work this out as to why it goes up skewed. Apart from that, the info here was spot on in doing this myself. Bit of cursing but doable. Any thoughts………?
1967 XR Falcon Wagon, Super Pursuit…….for now. *****XR PARTS WANTED******* |
10-10-2011, 11:32 PM | #2 | ||
i have the same problem had new motors fitted in both passenger side is sweet but drivers side is good up until half way cant figure the problem out
11-10-2011, 12:02 AM | #3 | ||
Critical Thinker
mine tend to get funny with the buttons. had the terminals cleaned on the buttons and its worked for about a year, now its not working again. wont work in either passenger or driver controls. Could this be regulator issues or do the button terminals need recleaning?
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
11-10-2011, 08:20 AM | #4 | |||
11-10-2011, 11:39 AM | #5 | ||
yes it seems to actually be an alignment problem with the drivers door window, as the window goes up on mine it gets half or two thirds the way up then window seems to hit a sloppy spot in the guide, and the top rearmost corner of the window digs into the channel and almost stalls the motor,
i`ve noticed if i hold a little force to keep the window forward it goes up like lightening, been meanig to tackle mine for a while but finding it hard to get motivated lately |
11-10-2011, 10:26 PM | #6 | |||
12-10-2011, 12:34 AM | #7 | ||
Bugger!
The crappy plastic plate that slides up and down wears out where it rubs on the metal. Last time mine went, i made a little metal plate insert to protect it. That worked well but took a lot of patience.....
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
22-10-2011, 09:10 PM | #8 | ||
Do you or anyone know where to get that crappy plate from? and i take it its the one on the door handle end. And how hard to fix. Thanks
22-10-2011, 10:02 PM | #9 | ||
Bugger!
Nobody seems to stock one!
You'll find it's in the centre, the plate runs up and down the guide in the centre.
24-10-2011, 08:02 PM | #10 | ||
LIFELONG DJR SUPPORTER
To make your windows wind up like new, lubricate the channel rubbers with Silicon Spray lube.
