Old 03-11-2005, 02:19 PM   #1
Sourbastard
Contributing Member
Sourbastard's Avatar
Default Brake Pads
Time has come to replace the Brake Pads on the Ute.
Whats everyone using and what can they recommend?
Anyone using EBC Greenstuff?
1965 XP Falcon Deluxe Sedan
1978 XC Falcon Wagon Rallypack
2003 BA Fairlane G220
Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM
Sourbastard is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 02:23 PM   #2
JC
Miami Pilot
JC's Avatar
Bendix Advance are pretty good all rounders. The pads you should get depend on what you want to use the car for, but Advance are a good compromise between effectiveness, resistance to fade, lack of dust (though there is always dust), no squeal and a good feel through the pedal.
Ford Performance Club ACT
Old 03-11-2005, 02:30 PM   #3
Sourbastard
Contributing Member
I had a fair bit of trouble with my last set of Bendix Advance which chewed through my stock rotors like they were butter.
I'm runnnig Ferodo Excels at the moment, which are ok but very dusty.
Old 03-11-2005, 02:49 PM   #4
Mechan1k
Mechan1k's Avatar
I just has Bendix Advance put on the front ... and they have been great ... my rotors needed replacing and was told that I'd have squealing issues and disc warping ... funny thing is that I don't though and the pads have been great. I have great peal feel ... and fade is rare (even when loaded right up.)
I have heard the Greenstuff chew through the rotors quite badly ... but the Blackstuff is kinder on the discs and is just as effective in braking performance ... the Greenstuff works better when you really heat the brakes up though.
I was advised (when i get the Tickford rotors and 4-piston calipers to go with the Blackstuff if i wanted to save my discs and still have good braking performance for courier work/heavy city driving under load.
I have heard good things about Ferodos ... they wear kinda quick though ... but braking is excellent.
Old 03-11-2005, 03:00 PM   #5
The Dok
The Dok's Avatar
I put Ferodos on mine (AU1 wag) @6 mths ago. Nasty nasty pads, dusting squealing ba$tards of things. I thought.....ok, lets try that anti squeal (Dynagrip) spray....worked well for @200ks, now it seems to squeal worse...can't wait till I can replace these pigs of pads & upgrade to the Bendix brand which are in the rear & on my EF & have never been a problem.
:Up_to_som
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 03:01 PM   #6
Sourbastard
Contributing Member
Yeah my Ferodo's have worn in about 11 months, but I was told they are not very hard on the rotors. I'd rather replace pads then rotors any day.
Old 03-11-2005, 03:13 PM   #7
Mechan1k
Mechan1k's Avatar
Same I'd rather change pads than rotors ... especially when i upgrade to the 330mm discs later on.
I'd hate to the Brembo package ... a TS50 was in at Cresent Motorsport the other day ... it needed new rotors as they were under minimum thickness .. and needed new pads ... one new Brembo 360-something mm rotor = $1000 ... OUCH ... the pad was something like $250 per pair ($500 just for the front pads all up).
Found out the part number on the T3 TS50 was the same part number as the Ferrari F40/F50.
Old 03-11-2005, 03:21 PM   #8
cArSiK
How about Bendix Ultimates? Ive only heard good things about them....thats what i plan on putting on the XR once my current stock ones wear....
Anyone know how Ultimates are on rotors?
James
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 03:35 PM   #9
xr8 007
xr8 007's Avatar
Ferodo formula pads at the front and ferodo XL's in the rear......If EBC made them for the seriers II on wards i would go for them but they dont so i'll settle for the Ferderal mogul's Ferodo.
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 03:49 PM   #10
xr8ute
Back on the road
xr8ute's Avatar
They will chew your stock rotors like Pacman
Ferodo Formula's are the way to go IMO (not Excel). I paid about $200 at Autopro for a set to suit AU1 fronts....probably much cheaper from one of the performance brake specialist importers.
The Bendix Ultimates w/stock rotors, had good bite, and pulled up well....but they used to fade real quick (scary on old pac hwy). They annihilated the stock rotors.
I fitted Ferodo Formulas w/DBA slotted about 60,000kms ago. They pulled up a little better than ultimates, firmer pedal than ultimates, and they just dont fade....Never took them to the track though. Pads have just run out, rotors look fine (no ridge).
I'll be using Ferodo Formula DS2500s (I had DS2000's) front and Formula Excels on the rear next pad change along with some good fluid i.e. Motul RBF 600. Maybe some Goodridge braided lines too.
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 04:06 PM   #11
FTE217
T3/Sprint8
FTE217's Avatar
I vote for the Formula's also, have them with the DBA4000 slotted. Work great,bit of dust but not as bad as Ultimate's.
You got it about right xr8ute.
I have had slotted rotors on my AU for over 90,000k's mind you I have worn 3pairs at the front but I drive hard and I get them cheap luckily.
Used many pad names over the years and atm for the money Ferodo have it right for now from sources in the game.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
FTE217 is online now   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 04:07 PM   #12
Sagerian
Custom User Title:
Sagerian's Avatar
I made the mistake of Ferodo's on the front... Still squealing. Currently waiting for the buggers to die.
____________
Just sometimes, in between the first cigarette with coffee in the morning to that four hundredth glass of cornershop p**s at 3am, you do sometimes look at yourself and think... this is fantastic. I'm in heaven.
Sagerian is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 04:09 PM   #13
cArSiK
Do the formulas squeal alot?
James
Old 03-11-2005, 04:16 PM   #14
FTE217
T3/Sprint8
FTE217's Avatar
After a month or so yes but I did the wrong thing of not getting the rotor skimmed and thought that was the reason, got them skimmed and caked on some anti squel goo at the back of the pads and there fine for ages now.
Bucknaked has the same combo, I knew he had some clip issues but no other issues.
Daily Macan GTS
Old 03-11-2005, 04:19 PM   #15
Sourbastard
Contributing Member
Incase anyone is interested, these are the prices for the Ferodo gear from Repco as of 2 minutes ago.
Ferodo Foruma DS2000 Front Pads $181 per pair
Ferodo Foruma Excel Pads Rear $66.99 per pair
Old 03-11-2005, 04:26 PM   #16
buickman
buickman
buickman's Avatar
Yep I found that when I had the Ultimates they really chewed the front rotors quick. I've been running the Bendix Advance for the last couple of pad changes with 2 front & 1 rear pad & have found them dust free & doing the job well for city & highway braking with normal rotor wear .
buickman
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 04:30 PM   #17
FTE217
T3/Sprint8
FTE217's Avatar
I am not a Ferodo spokesman but from my experience I have had an issue with any brand from time to time over the last 25yrs....
Daily Macan GTS
Old 03-11-2005, 04:49 PM   #18
Sagerian
Custom User Title:
Sagerian's Avatar
Fair enough.
I've noticed they do at least stop the car.
____________
Old 03-11-2005, 05:06 PM   #19
Sourbastard
Contributing Member
Fair enough.
Sounds far too functional to me.... maybe add a mugen sticker to your brake calipers for that extra ricey flavour.
Old 03-11-2005, 05:12 PM   #20
Sagerian
Custom User Title:
Sagerian's Avatar
I was thinking about getting brake pad spinners.
____________
Old 03-11-2005, 05:43 PM   #21
BuuBox
I put $29 brake pads in the front my EB a few months back in a bit of an emergency, and I was surprised at how bad they weren't. I don't get dramatic fade coming down Mount Dandenong as I used to regularly, and haven't had any problems with dust or excessive squeeling.
That said, I've got a set of Bendix Advance (with asbestos) ready to go in...
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 06:36 PM   #22
loxxr6
XB in parts...
loxxr6's Avatar
I'm sure they're the ones I have. They've prob been on for less than a year and I haven't had any dramas. They are a bit dusty tho.
Daily Driver 2019 Ford Escape...looking for XR6T's.
loxxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 09:36 PM   #23
AUGhiaV8
Posts: n/a
Have used EBC... they rooted the rotors. Ferodo Excels... NO grip when cold (living on a hill is scary). Will now go back to Lucas pads which have always been great!
Old 03-11-2005, 10:20 PM   #24
cArSiK
are your rotors still stock?
Old 03-11-2005, 10:27 PM   #25
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
bendix ultimates are ultimate..
just so bloody dusty.. i just weighed it up that a bit of black dust on my front wheels doesnt bother me coz i can now stop on a 10 cent piece...
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2005, 08:21 AM   #26
OldManGhia
OldManGhia's Avatar
I replaced a set of Zircon pads (never heard of them before) that were squealing with Bendix Advance pads on standard rotors. No squealing anymore and dust is very minimul. Performance for me anyway is more than acceptable.
Anyone want a set of Zircons?
OldManGhia is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2005, 08:49 AM   #27
Casper
Contributing Member
Casper's Avatar
Sounds identical to the setup I'm about to do. Funny about that, wonder who recommended them? : (thanks mate)
Older, wiser, poorer.
Old 06-11-2005, 07:41 PM   #28
xr8 007
xr8 007's Avatar
eheheheheh anytime buddy!!!!
Old 06-11-2005, 08:15 PM   #29
SVR73
Mr Polish
Very happy with my EBC greens and slotted rotors, from my experience, you have to give them a few hard times when bedding in or they glaze up.
However performance at least with single piston calipers is great and my new 18's help with cooling much more than my 16's which have very small gaps to let air in
After a couple stops, they work fine from then on.
Extremely low dusting, seal or wax the wheels to prevent dusting between washes
However blackstuff's may be an option if you want more durability
Detailology colour fx detail studio and R&D Lab
SA's leader in auto detailing and paint treatments
SVR73 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2005, 12:03 AM   #30
ClassicAU
i just had a bit of an issue with what i thought was my last set of pad on my rear brakes sqeeking and rubbing, but turned out to be a bent left rear axle! :
but i just changed to Bendix Advanced and have not heard a peap out of them so far. I just had to make sure i bedded them in properly for the first 100kms or so. They seem to stop very well, although i am not gain to hammer them just yet, dont want them to move and end up squeeking on me too.
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
