Old 12-10-2007, 07:00 PM   #1
aufutura_bloke
Default tensioner O Ring
can someone please tell me how to replace the O RING on the TENSIONER. Im assuming ford mean the tensioner pulleys.
2001 Ford Falcon Futura Classic SVP
Web-Site:
http://www.aufalcon.com/cgi-bin/index.cgi?act=item&i=394
aufutura_bloke is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 07:33 PM   #2
sly
Sly like a G6
sly's Avatar
That'd be the oil seal on the timing chain tensioner. Remove snorkel, fans, loosen belt, remove power steering pump from bracket, remove bracket and there's the tensioner on the driver's side of the engine. Inner bolt may undo cleanly or the whole assembly may undo. I've done this numerous times (once for each camshaft change) but I can't tell you exactly where the O-ring is. I have to do this myself soon as I have quite a good leak, but I suspect you'll be doing yours before me.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2007, 11:30 PM   #3
trick_xd
I build your wish list...
trick_xd's Avatar
There is no good fitting " O " ring that you can buy
on this part there is 2 "O" rings on the filter
And when you remove this part there is also a O ring on there as well
BUT there is not a good " O " Ring that you can get to fit this part
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 12:29 AM   #4
sly
Sly like a G6
sly's Avatar
Some others on here reckon they've got kits from Ford dealers for around $20 that stop the leak. Haven't tried myself yet, will find out eventually. Great photos though, spot on. Is that the "special tool" for releasing the tension or did you mod the allen key yourself? I always use a bog stock 3mm allen key.
Sleeper, anyone?
Old 13-10-2007, 08:37 AM   #5
trick_xd
trick_xd's Avatar
Yep I " Modded " it
at Work I was doing from 2 to 5 Head gaskets a week So I have it down Pat ..
Old 13-10-2007, 08:56 AM   #6
au2sw
Blown 5L coming
au2sw's Avatar
i had to do this just recently, and i didnt have to remove snorkle or fans. you can get to the belt tensioner with a 3/8th drive breaker bar then undo the p/s pump to get to the chain tensioner. i also added some ultra grey around the seal for added leak prevention.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 09:25 AM   #7
blackers10
blackers10's Avatar
goto Motion Industries(www.motionind.com.au).. we have a million different size O rings
compared to supercheaps "assorted" pack
also there is some good loctite products that may help
Old 13-10-2007, 09:34 AM   #8
sly
Sly like a G6
sly's Avatar
If you're strong enough you can deflect the belt enough to R&R it just by grabbing it & giving it a bit of a tug. My assortment of 1/2" drive extensions are either too short to reach through the PS pulley or long enough to foul the ratchet handle on the fan shroud, so I can't do it without pulling fan assy, which means pulling the snorkel first.
Fair enough he should try it without removing fans & snorkel first, but it's not too hard to do so if he needs to.
Sleeper, anyone?
Old 13-10-2007, 10:18 AM   #9
waggaclint
waggaclint's Avatar
The bit that you left bolted to the block has an 0-ring on and this is what leaks mostly....and you can buy them...
waggaclint is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2007, 09:57 PM   #10
trick_xd
trick_xd's Avatar
Yep I fell asleep and left that Pick out ...
even the O ring there is hard to find to get one to fit right.
I like to use selastic to put behind it so it does not course any trouble.
Old 14-10-2007, 12:33 AM   #11
sly
Sly like a G6
sly's Avatar
Hopefully customer gaskets, not your own...
Sleeper, anyone?
Old 14-10-2007, 12:33 PM   #12
trick_xd
trick_xd's Avatar
LoL Yep
I don't work as a Mechanic now But still do "back-yard's"
Old 14-10-2007, 06:32 PM   #13
GK
Walking with God
GK's Avatar
Great pics trick!
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 14-10-2007, 06:47 PM   #14
FS5
is that an e series tensioner,looks quite a bit different to the ones i've seen in my au engines.
the au tensioners i've seen don't have an o ring on them .just the black housing that screws into the block.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2007, 07:00 PM   #15
FS5
here's a pic of an au one
Old 14-10-2007, 07:23 PM   #16
trick_xd
trick_xd's Avatar
That is the tensioner You have a pic of there ... It sits behind the "Disc" in the pic of mine
Where the Allen key is sticking out of is the tensioner that you have picks of.
GK ...I did a hole step by step guide with pic's and what tools needed to do a Head gasket change and also a water pump change .
Old 14-10-2007, 07:40 PM   #17
FS5
ok now i'm confused,whats the bit in your bottom pic sitting above the alum key to the left? (in your 1st post)
i assumed it was the tensioner,my au i6's don't have this piece.
Old 14-10-2007, 09:41 PM   #18
trick_xd
trick_xd's Avatar
OK first you have this
So you undo the 14mm "bolt" and remove it
like this
Then you put the Allen Key into the center and turn it anti clockwise
While you Put a screw driver down from the Top and Help push the tensioner back By pushing on the chain Guide.
Then when You undo that "Disc" you will see the tensioner ....
BUT if all you do as I say You DO-NOT have to do anymore to the tensioner then remove the "bolt" and release the tensioner with the Allen key and screwdriver
Old 05-10-2011, 02:48 PM   #19
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: tensioner O Ring
Help,
I can not get the inside blot to undo. Each time I turn the bolt the ouside ring starts to unscrew as well. Does this matter? Do I have to remove the whole outside case then undo the centre bolt?
UK
Old 05-10-2011, 03:58 PM   #20
Whoosha
AU DIE HARD
Whoosha's Avatar
The 1 I did. did the same just took the whole lot out then replaced in 2 separate pieces
Originally Posted by Riksta
Old 05-10-2011, 04:44 PM   #21
Uncle_Ken
Uncle_Ken's Avatar
Its all out now. Have ordered the new o rings. Pick up tommorw.
UK
Old 23-10-2011, 11:21 AM   #22
Uncle_Ken
Uncle_Ken's Avatar
Ok after a week or so he chain is nosiy and stalling when run on gas. So I have removed the tensioner (again) and it has three states
1. undone
2. half way tight
3. Fully closed
You can see from this picture what the case locks onto
So my questions are.
a. Can I reset the tension outside the case, slide it in and then just tight it up or
b. slide back the outer caseing, then slide it onto the untighted spring (makeing sure nothing goes into the engine) and then set it?
And what settings, undone, half thighten or full?
UK
Old 23-10-2011, 03:18 PM   #23
Uncle_Ken
Uncle_Ken's Avatar
Its back in now. Taking it for a run soon. Questions above still stand
Uk
Old 26-10-2011, 10:02 PM   #24
blueau
you can swap the larger oring for an alloy sump plug washer, tends to work alot better
blueau is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 03:54 PM   #25
Uncle_Ken
Uncle_Ken's Avatar
They do look the same in size. Will try and grab a sound bite of the engine to see what everyone thinks.
UK
