24-12-2011, 11:07 AM | #1 | ||
I have had a ticking sound when i lightly apply the brake for a few months now. I have changed both discs and pads and its probably worse than before. Has anyone experienced this?. Even whilst driving it seems the pads are floating about, front and rear, going over bumps etc. (rechecked them and put anti squeel, no luck) Front left is by far the worst. Any help would be great.
cheers jordan |
24-12-2011, 11:29 AM | #2 | |||
Next upgraded Mk1 Leopard
UK
24-12-2011, 11:32 AM | #3 | ||
Series 3 Au xr8. QFM Pads and Protex rotors
24-12-2011, 11:52 AM | #4 | |||
Just another mock-up..
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
24-12-2011, 02:13 PM | #5 | ||
Dont think so, couldnt be 100%, will have a look next time the wheel is off. Tick is also when driving.
24-12-2011, 05:10 PM | #6 | ||
you could run around the ends of the pads with a center punch(on the metal part), swelling the ends of the brake pad backing plate, effectively making them longer to take up any excessive clearance, i have also seen some blokes use some high temp silicon on the back of the pads(not on the friction material side) to help alleviate rattling pads.
24-12-2011, 06:51 PM | #7 | ||
With my sons Tickfords I had to make the clips tight so they didn't rattle. Never had any issues with my AU since I changed to slotted rotors.
UK
