Old 05-10-2005, 12:37 PM   #631
NZ
NZ's Avatar
ef xr8
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 12:43 PM   #632
Paris Hilton
Custom User Title
Paris Hilton's Avatar
sportsman?
Paris Hilton is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 12:53 PM   #633
bprint xr8
more posting less lurking
bprint xr8's Avatar
correct nz. Your go
BA XR8 Devil R - SY Territory TX AWD - MQ Nissan Patrol 302c - GQ Nissan Patrol
bprint xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 03:11 PM   #634
NZ
NZ's Avatar
What was the primary reason for the swirl port in the ea cyl heads?
Old 05-10-2005, 03:46 PM   #635
Walkinshaw
Two > One
Walkinshaw's Avatar
(1) to reduce chamber volume to bring the CR up to 8.8:1
(2) to keep intake and exhaust charges seperated
1978 LTD - 408ci - 11.5@120.6mph -
2004 S4 - 4.2 - M6 - quattro -
Walkinshaw is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 04:21 PM   #636
eb2fairmont
To increase swirl promoting better mix of the fuel and air.
eb2fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2005, 04:58 PM   #637
Walkinshaw
Two > One
Walkinshaw's Avatar
Thing is the 4.0 heads do not have the swirl port. Traditonaly a swirl port is used to promote better cylinder charging and to pull intake charge away from the chamber walls.
Old 05-10-2005, 07:13 PM   #638
NZ
NZ's Avatar
eb2fairmont: your on the right track it does do this but theres a reason why they wanted this.
Walki: may be correct answers but not the ones I want.
Old 05-10-2005, 07:16 PM   #639
EFFalcon
Last warning
EFFalcon's Avatar
coz its a bad idea... as was the EA :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 05-10-2005, 08:42 PM   #640
Walkinshaw
Two > One
Walkinshaw's Avatar
Karl, was it a way of achieving emissions?
Old 05-10-2005, 08:47 PM   #641
EFFalcon
Last warning
EFFalcon's Avatar
Boost
Old 07-10-2005, 09:38 AM   #642
mcflux
mcflux's Avatar
As an real-time means of destructively testing the longevity of head gaskets?
Old 07-10-2005, 10:14 AM   #643
Kenaz
Kenaz's Avatar
Some of these questions are way too technical.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2005, 08:47 PM   #644
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
attempt to improve fuel economy?
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2005, 09:17 PM   #645
NZ
NZ's Avatar
Argh where's my reply go!
The swil chamber was there because EA was orginally going to get EGR. Its primary reason was to mix the exuast gasses properly. It turned out they were meeting emissions without EGR so it was canned. It was too late to change the head casts to the swirl stayed and the heads were changed for the 4.0.
AU is also the same deal. I haven't seen an AU head but apparently they have a half swirl. Same deal as ea, was designed for EGR but didn't need it again.
Old 08-10-2005, 12:08 AM   #646
Walkinshaw
Two > One
Walkinshaw's Avatar
I'm gonna take that as a win!!
so.......Here's one which extends into the AU.
What is the diffrence in the BBM from EF==>EL
and
What is the diffrence in the BBM from EL==>AU
Old 08-10-2005, 05:56 PM   #647
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
EL===>AU the maf/air temp sensor is different.
cant remember the difference between ef/el
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2005, 06:06 PM   #648
Perana
Perana's Avatar
EF, EL and AU all had different mountings for the piping as well as the EF/EL --> AU had different temp/Map sensors
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2005, 06:07 PM   #649
LUXO_8
windsor user
the casting on the EF BBM is different to EL, as it has the mounting holes for the EF dual pipe plastic intake.
no idea on AU though
edit..bah too slow
Old 12-10-2005, 12:01 AM   #650
1TUFEA
MONTY is Alive !
1TUFEA's Avatar
NEXT ! no au Q's Please !
Originally Posted by bindi
I may be a grumpy redheaded bigbutted chick.
1988 Ford Fairmont EA Series 1
MODS: Hurricane Extractors, Red dash light, Fake Xenon Lights, Mpfi Conversion, Dumpage, 17" ANZ Mayhems (Chrome)
TO COME: 5 speed trans, 4.11 LSD, Carputer, Stage 2 cam, Major Head Work . :
1TUFEA is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 06:39 PM   #651
micksta
micksta's Avatar
what was the answer to the question ?? since it was EA->EL related...
micksta is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2005, 11:17 AM   #652
Thanatos
E-Series Owners Club
Thanatos's Avatar
All three have different castings for the upper half of the manifold.
The difference between EF-EL was the mounting points on the top of the manifold for the intake piping.
The AU manifold has the same mounting points as the EL one, but it has no pipe coming out for the MAP sensor hose to connect to (as the AU had an IAT and MAP in one). The hole where the IAT sensor goes is smaller and doesn't have a thread in it. The area immediately after the throttle body is different (EF & EL look like they have a space for something to be mounted there, but the AU doesn't). And the steel vacuum tree is different (although that can be unscrewed so i don't know if it technically counts as a difference :P).
The lower halves of the manifold are all indentical ;)
Thanatos is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2005, 11:39 AM   #653
Walkinshaw
Two > One
Walkinshaw's Avatar
Bingo. The last few ideas are all correct.
Old 10-11-2005, 02:37 PM   #654
Stock EB
Carmon next question hahaha
Stock EB is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 08:11 AM   #655
sik mk1 cortina
yeah, next question, ive been hangn out for ages!
sik mk1 cortina is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 12:38 PM   #656
BLACK 6
yep? hook me up with a q.)
BLACK 6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 01:24 PM   #657
Damo
I got a Question
Why is this thread back at the top ?
:P
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2005, 01:28 PM   #658
CruizinEB
because my idiot mate (Stock EB) had to bring it up, i will have a word with him at TAFE tomorrow
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
