Old 17-01-2012, 09:46 PM   #1
samsy351
351XB - Underbelly II Car
samsy351's Avatar
Default How much work ? AU seats into ED
Hi all ... can someone tell me How much modification to fit AU seats into an ED ?
Ive heard that you may even be able to just unbolt all the foam padding from both seat frames and swap them over for an easier conversion , is this true??
any ideas?
Cheers.
FALCON XB 351 - UNDERBELLY II CAR
samsy351 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2012, 05:17 PM   #2
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Default Re: How much work ? AU seats into ED
Just swap the 'feet' of the seat rails over.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2012, 09:46 PM   #3
samsy351
samsy351's Avatar
Old 18-01-2012, 11:27 PM   #4
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Why. and then no not really at all. ba seats will go straight in with a spacer on the inside rear leg. au seats are in my opinion th worst ford seat and rail setup ever. And theres no swapping the feet over, have a look at the two seat design they're completely different and they will sit way way to low.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2012, 08:08 PM   #5
samsy351
samsy351's Avatar
Just considered AU seats cause I could get some cheap thats all. Its just for the "run-a-round" ...the current seats in it are *****.
Thanks for the info .
Old 20-01-2012, 05:38 PM   #6
Nikked
Oo\===/oO
Nikked's Avatar
Actually, its is just a case of swapping the feat over. Its been done before...even threads on it on fordmods.
Its the same way people put EF-EL seats into the EA-ED's (unless you want to weld the floor hump in)
So, again, to put Au seats in, use the feat from your ED seats, the are rivited/welded from factory.
IF you have a good welder (not a gassless mig lol) weld the ED feet onto the AU rails.
\≡≡T≡≡/
Old 20-01-2012, 09:25 PM   #7
samsy351
samsy351's Avatar
Thanks Nikked, .....Ive also come across some BA seats cheap aswell but they are from a ute .. are the ute ones the same as a sedan??
Old 21-01-2012, 12:12 AM   #8
Nikked
Oo\===/oO
Nikked's Avatar
Ute seats have a quick release for them to flip foward, other then that they are the same.
Keep in mind, if they are electronic, you'll need to wire them up.
\≡≡T≡≡/
Old 24-02-2012, 11:33 AM   #9
fgtpsi
fgtpsi's Avatar
Is there any difference in putting ba seats into an xh? Not sure what the floor pans like?
FG MKII XR6T UTE
fgtpsi is offline   Reply With Quote Multi-Quote with this Post
