Old 27-11-2005, 05:57 PM   #1
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Default Are you allowed to do this?
$24 cheap mod. Must suck air in from front.
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 06:18 PM   #2
snypereb
[EBGLT]
snypereb's Avatar
What is it doing mate?
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 06:22 PM   #3
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Does it go to the airbox or throttle body? It's got a pretty good chance of sucking in some water there.
You could probably be defected for clearance with that front pipe, and with the exposed screws sticking out of the intake as well...
Old 27-11-2005, 06:23 PM   #4
Casper
Contributing Member
Casper's Avatar
Not to mention sucking up small animals :P
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 06:25 PM   #5
Clarke AV
Clarke AV's Avatar
Oops, Wrong pick
Old 27-11-2005, 06:43 PM   #6
snypereb
[EBGLT]
snypereb's Avatar
Explain to us what its doing mate and why you did it?
[EBGLT]
Old 27-11-2005, 06:51 PM   #7
Clarke AV
Clarke AV's Avatar
I was running way to rich’
Old 27-11-2005, 06:57 PM   #8
snypereb
[EBGLT]
snypereb's Avatar
Oh ok cool looks ok maybe a clean up on the screws!
[EBGLT]
Old 27-11-2005, 07:01 PM   #9
HOON69
HOON69's Avatar
looks abit tight is that the pipe running up past the pullies
HOON69 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 07:05 PM   #10
Racecraft
they call me Tibbo
Racecraft's Avatar
so its is just an air 'ram' intake then.. I cant see any problems with it so long as it feeds before the air filter to catch any road muck
And if you can squeeze the pop rivot gun in to the gap in the bar, put the rivots in head down to neaten it up alittle
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 07:10 PM   #11
Fishman
Fishman's Avatar
I did a similar sort of thing with the EF and ended up ripping the pipe out from the front and driving over the bastard in a carpark (in the rain too). Went back to the original air intake.
Fishman is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2005, 07:13 PM   #12
snypereb
[EBGLT]
snypereb's Avatar
Watch out scuffing it when your parking to it will slowly wear away if your always scraping up against the gutter!
[EBGLT]
Old 27-11-2005, 10:10 PM   #13
EDXR8
EDXR8's Avatar
It wont help lean it out at all, but it will provide a decent amount of cool air. The only issue I see is with ground clearance, most people who duct air from the front bar like that cut a hole in the wheel arch under the airbox and run the duct through the wheel arch to the front spoiler.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
