Old 29-11-2005, 10:11 PM   #1
snypereb
[EBGLT]
snypereb's Avatar
Default Diff Ratio
What do all these numbers mean with diff ratios? How do i change mine i need some more take off speed?
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 10:13 PM   #2
EBFalcs
the higher the number the quicker the take off, but you will have less top speed and less fuel economy, the number means how many times the axle turns to how many times the tailshaft (i think) turns, 3.23 axle turns to one tail shaft. =3.23:1 diff
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 10:24 PM   #3
snypereb
[EBGLT]
snypereb's Avatar
Thats helpful thanks mate gathered it would use more fuel witht he higher diff ratio. How do i go about getting a higher diff ratio?
[EBGLT]
Old 29-11-2005, 10:26 PM   #4
EBFalcs
i would go to a wreckers,
Old 29-11-2005, 10:34 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
What do i do there just talk to them about what i want to do and just go from there?
[EBGLT]
Old 29-11-2005, 10:36 PM   #6
EBFalcs
yeah.
Old 29-11-2005, 10:37 PM   #7
EBFalcs
one more thing. you will have to get your speedo re-calibrated
Old 29-11-2005, 10:46 PM   #8
snypereb
[EBGLT]
snypereb's Avatar
oh ok why is that?
[EBGLT]
Old 29-11-2005, 10:49 PM   #9
EBFalcs
well the different ratios mean the wheels will be spinning at a different rate to the trans, than what they were at factory.
Old 29-11-2005, 10:52 PM   #10
snypereb
[EBGLT]
snypereb's Avatar
Oh ok cool we can do that through a dyno tuner yeah?
[EBGLT]
Old 29-11-2005, 10:53 PM   #11
EBFalcs
i dunno, probably
Old 29-11-2005, 11:04 PM   #12
snypereb
[EBGLT]
snypereb's Avatar
Where else then?
[EBGLT]
Old 29-11-2005, 11:06 PM   #13
Walkinshaw
Two > One
Walkinshaw's Avatar
You had it the wrong way round.
3.23:1 = the tailshaft turns 3.23times for one turn of the axle.
But yes, numericaly higher diffs will help with take off (to an extent)
Old 29-11-2005, 11:10 PM   #14
darnoldrs
I have 3.45:1 This seems to be a grate ratio for me. I have found it to give good fuel economy (9-10L per 100km on a trip @ 110-120) and good take off also (0-60mph=6 sec), with a V8 manual.
By the way, the higher the number, the lower the diff ratio. eg. 2.77:1 is a hight ratio. 4.45:1 is a low ratio.
The changing the speedo can be done by a machanic by changing the "speedo drive" gear in the gearbox. not sure on a cost.
darnoldrs is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2005, 11:10 PM   #15
snypereb
[EBGLT]
snypereb's Avatar
Thanks mate!
[EBGLT]
