Old 24-05-2012, 01:16 PM   #1
351henryv8
ef fairmont 5 litre
351henryv8's Avatar
Default 06 Fiesta - Ignition Issues
Hi
A friend of mine has the following problem, would appreciate any help!
Travels daily from Goulburn to Canberra and return (90km each way). The problem is consistent and happens on every trip, in both directions.
Car always starts first time every time regardless of weather.
After about five minutes of driving the speedometer stops working as does the odometer. After a further five minutes, on the highway, at around 110kph, the engine will stop. Turn the key from ON to OFF and back to ON and the will start / fire again (car stilll moving, manual gearbox). This happens about 5 to 15 times on every trip, so the speedo andodometer will not be working for anywhere up to 40 Kms. This happens so consistently that you can pick when and where it will occur. More dangerous at night because the HEADLIGHTS also turn off when the engine dies. FORD and auto electrician unable to identify the problem. TACHO remains working (when speedo stops) and all the other electrics are fine. He has tried warming up the car but no difference. I suggested checking all the fusues and contacts.
Any ideas appreciated.
TA
Kim
351henryv8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2012, 06:04 PM   #2
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: 06 Fiesta - Ignition Issues
Check all the earths from the ECU and body control modules.
Old 24-05-2012, 07:32 PM   #3
Fiesta_Man69
What you describe is extremely dangerous: take it to Ford: if they refuse to fix it I'd sell it - life isn't worth it; if engine is cutting out at speed (brakes? Steering? Lights too?)
Fiesta_Man69 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2012, 03:31 PM   #4
fonfe
RS shop's technician
Sounds like corrosion in the bcm connector.
Advertising removed
fonfe is offline   Reply With Quote Multi-Quote with this Post
