26-11-2005, 09:14 AM | #1 | ||
Bring on the lion...
I have a el 4.0 and have just recently got my head shaved and put an xr6 cam in, but it is missing like crazy and stalls. i put all new plugs and leads on and replaced my coil which also went. What are the chances of there being a bent valve of one not sealing properly?
26-11-2005, 10:02 AM | #2 | ||
what are the chances you have the leads on in the wrong order?
project #1: Ea series1 Spac conversion to straight gas; 351Cleveland; T5; EB dash; sunroof and more as I get to them. :evilsasmo Fully road legal and cruising in QLD!! --------------------------------------------------- Happy dealings with; PROTD, !gn!t!on, Big_waity,Phongus |
26-11-2005, 10:48 AM | #3 | ||
yer thats sound's like it
u probbally got a lead wrong i no all too wel:( |
26-11-2005, 11:22 AM | #4 | ||
Gunna girlie-man
it could be the head gasket not sealed properly, ie. losing compression. also check for a cracked distributor cap, or throttle body adjustment
26-11-2005, 02:34 PM | #5 | ||
ThaKS guys, ill check all these and ill get back to you. I am getting a compression tester this arvo, ill keep yas posted. cheers
01-12-2005, 05:12 PM | #6 | ||
ended up being a bent valve, but thanks for you help anyway
