09-07-2012, 12:59 AM | #1 | ||
when i bought my 2002 xr6 with 116000ks the ford dealer said the rotors had been machined due to vibrations under load the problem is still there braking down from 100kph should i replace the rotors or have them re machined thats if they were done in the first place thanks
09-07-2012, 10:08 AM | #2 | ||
Next upgraded Mk1 Leopard
I would get new rotors
UK
09-07-2012, 10:46 AM | #3 | |||
Walking with God
There's a stack of debate and opinions on which combo's work best, but many here contend that a good combo would be either: QFM Pads - One step above stock. RDA Slotted rotors QFM Pads - One step above stock. DBA Sotted rotors Stock and a little above normal driving situations will see the above recommendations serve you well. There are many fans of either rotor (my choice is RDA) as I've had both and the QFM pads pull up well, with minimal dust and long life. Others will advise you on different pad choices, often such recommendations are from members who drive on track days and such and their experience is valid, as I don't use either of my AUs on the track. Also, if you're opting for track work, you would probably go slotted and dimpled rotors instead of just slotted. Cheers, GK
09-07-2012, 10:53 AM | #4 | ||
+ What GK said
UK
09-07-2012, 01:14 PM | #5 | ||
Flairs - Truckers Delight
With an AUII/AUIII I wouldn't bother with slotted rotors - new normal ventilated units with good QFM pads will provide you with pretty good feel. I find that slotteds chew through the pads too quickly and dust up too much for the small (to none) benefit provided in regular driving. But yes I would very much recommend that you replace your rotors if they've already been machined once.
09-07-2012, 01:25 PM | #6 | ||
Get new rotors and pads. I have recently got my brakes changed and I am very happy with them. Braking is smooth even at high speeds and braking distance has significantly improved. I am using RDA Slotted Rotors and Bendix Heavy Duty Pads.
Paid $400 all up for the parts |
09-07-2012, 05:59 PM | #7 | ||
Critical Thinker
Another vote for QFM HPX pads and new rotors.
Depending on your driving style will be what rotor you choose to get. i.e. Normal day to day driving in urban traffic and some highways, a standard rotor with better than stock pads is the go. Spirited, urban, and hills driving I would recommend a slotted rotor with QFM HPX pads. I went one up again, still went with a RDA/DBA slotted combination front and rear with QFM pads, but I also upgraded the front brake lines to braided for better brake feel and went to a higher quality brake fluid to avoid boiling.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
09-07-2012, 09:56 PM | #8 | |||
UK
10-07-2012, 12:01 AM | #9 | ||
Critical Thinker
Lol. you love it UK.
