28-02-2008, 12:30 PM | #1 | ||
Tickford Equiped
Hey guys,
Just wondering whats involved in removing my current side skirts (tickford with the flare up the door) as i want to replace them with TE50 Skirts. Its mainly the flare on the door im worried about. These are "Glued" on with something arent they? What do i have to do to get it & the glue off??? Will the doors need a re-spray afterwards??? Cheers Col.
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
28-02-2008, 02:58 PM | #2 | |||
AU DIE HARD
If there factory fitted you will probably find there stuck on with black stic a flex type stuff if thats the case it has been known to a survive nuclear strike.. you have to bend them back and cut it off.. getting it of the paint is worse some solvents will make it go soft but may take paint off with it : . check out your local auto paint store to see what they recommend .. with any luck they could allso be stuck with a 2 sided tape much easyer to get off an the residue will come of with prepsol or wax and grease remover.. good luck with it
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
28-02-2008, 03:24 PM | #3 | ||
DUB
yeh im pretty sure they'd be stuck on with sikaflex, maybe try using some sort of razor blade to slice it ??...
28-02-2008, 05:32 PM | #4 | ||
Tickford Equiped
Bugger! So by the sounds of it doors will need a respray afterwards aswell. Looks like i have to budget that into everything aswell. Thanks for the help guys.
Col
28-02-2008, 06:15 PM | #5 | ||
_Oo===oO_
The EF rear door 'pods' were sicaflexed on, and there was also a hole drilled through the door with a screw holding the pod onto the door, if you open the rear door and look in the bottom corner you should be able whether there is one or not.
If it's sicaflexed on a razor blade is useless, sicaflex is incredibly tough. It's best to slide a long sharp knife (not *too* sharp lol) in between the door and the pod and 'carve' the sicaflex (like a roast). Make sure to bias the knifes blade towars the pod and put heaps of masking tape on the door and side mouldings [and door pod if you want it in good nick to resell] you dont want to accidentally scratch anything up. Once the pod's off mask around the sikaflex residue on the door and carefully slice it away as much as possible. Once theres only patchy sicaflex residue you can get it off pretty easily. I use orange power citrus cleaner on sikaflex which softens it but doesnt affect the paint, then rub at the residue with your fingers, nails until you get it off (it's time consuming and not alot of fun) |
28-02-2008, 06:54 PM | #6 | ||
Audi S3
leave the door flares on? shouldnt look too bad with the T3 skirts?
28-02-2008, 08:04 PM | #7 | ||
_Oo===oO_
They wont match up properly.
03-03-2008, 12:45 PM | #8 | ||
Tickford Equiped
As you can see the tickford flares dont really match up to the rear bar. Not to mention that the current side skirts have an indentation where the tickford flares sit over. The TE50 side skirts dont have this so they have to be removed.
03-03-2008, 12:57 PM | #9 | ||
_Oo===oO_
Yeah wont match up unfortunately
31-08-2012, 01:57 AM | #10 | ||
Old thread but if any 1 looks it up there's 3 screws on the inside of the door pull door card off with window up ull find them and yes the siciflex they use NEEDS a knife or you can use a heat gun on the inside of the door u get it quiet hot n it just slides off , then while hot scrap the rest off and se a solvent , ull always be left with holes tho unfortunately
