plug in three pin plug join the 2 yellow/white wires together and then join 2 yellow wire on harness, then grey wire goes to yellow/red wire on harness. yay or ney?
sorry you're not giving enough info here to give an answer what is the wiring for?
[SIGPIC][/SIGPIC]
sorry, altenator. I have a s2 ute with a 2pin altenator and the altenator light has been come on and off at random until today when it came on and stayed on. I have an s1 three pin altenator in the shed.
Came across this issue recently when converting my 6 to an 8. The 3 pin plugs only actually use 2 wires and they are the same colours as the 2 pin plugs! To use a 3 pin alternator you will need to simply change the connector on your main loom on the car side.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
ford actually do an adaptor for this
[SIGPIC][/SIGPIC]
thanks bartsau, i just wanted to double check before i went ahead.
#7 | |||
perhaps 1 for the useful au threads?
#9 | |||
as far as I know they are quite cheap
[SIGPIC][/SIGPIC]
