Old 29-10-2012, 10:16 PM   #1
FordFalconBF
2008 BF Futura
FordFalconBF's Avatar
Default Does anyone own a Haynes 2002-2008 Ford Fiesta repair Manual?
Hey,
I have one on order right now (Haynes Manual), but I don't think I'll get it before I need to fix two things.
I was wondering if someone could please scan the section on replacing the Water Pump and Replacing the auxiliary belt..
It's for a 2004 WP Mk6 Ford Fiesta 1.6 Petrol.
Thanks in advance,
Alan.
2008 BF Falcon Futura
2009 BF Falcon Wagon Dedicated LPG
Previous Cars:
2003 BA Falcon Wagon Dedicated LPG
1999 Ford Fairlane Ghia
XF Fairmont Ghia
Escort MK2 RS2000 Replica
FordFalconBF is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2012, 03:27 AM   #2
zabatron
Default Re: Does anyone own a Haynes 2002-2008 Ford Fiesta repair Manual?
I have a wp fiesta haynes manual here...according to the manual,no belt tensioner is fitted to the 1.6 litre Duratec engine as the belt used is the stretch fit type(just like a giant rubber band).The only way to remove the drive belt is to cut it.New,genuine Ford belts are supplied with several special plastic tools required to fit the new belt.To gain access to belt,there is a lower drive belt cover behind drivers side front wheel which must be removed(easy to do,just unclip power steering pipe and remove the 2 retaining screws,and you may also get better access to water pump by removing the rh side headlight.Water pump removal is pretty straight forward once you have the drive belt off.
zabatron is offline   Reply With Quote Multi-Quote with this Post
