Old 12-11-2012, 01:41 PM   #1
SVT8
SVT8's Avatar
Default AU V8 throttle cable assembly (photo required)
Would someone be able to post up a photo of the cable/bracket and spring underneath there V8 throttle body? Just cant remember how the dam thing goes
Iv hooked it up but im left over with a spring and a small black bracket piece :/
SVT8 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 06:44 PM   #2
fordman302
fordman302's Avatar
Default Re: AU V8 throttle cable assembly (photo required)
Hope these help
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 07:57 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
And the small bracket left over supports the square black bit of the loom, it bolts in front of the other one you can just see it in the right corner as you look at it I can get a better shot if you need it
Originally Posted by Riksta
Old 13-11-2012, 01:19 PM   #4
SVT8
SVT8's Avatar
Reckon you could get a photo of it all installed from underneath the throttle body? Maybee one with the air intake pipe off?
Would be much appreciated
Old 13-11-2012, 07:38 PM   #5
Whoosha
AU DIE HARD
Whoosha's Avatar
Shall grab some in the morning for ya
Old 14-11-2012, 11:22 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
From the front looking at the fire wall
On top looking down at the back of throttle body from pass.side
From driver side
cable bracket bolts to rear of T/B first then loom bracket over it
Underside to back of motor
Old 14-11-2012, 11:28 AM   #7
SVT8
SVT8's Avatar
perfect! thanks alot for all your help!
Old 14-11-2012, 05:10 PM   #8
FTe342
FTe342's Avatar
If this is for your T3 its different
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
