Old 16-11-2012, 04:32 PM   #1
block58
block58's Avatar
Default Shaking steering wheel
Hi all,
I think this might be a common issue in AUs as I saw it mentioned in one of those "what to look out for when buying an AU" threads, but I cant for the life of me find any info on it.
The issue is that the steering wheel is able to move up and down, its only about 2-4mm either direction but it means that bumps in the road are transmitted through it.
Is the fix as simple as replacing a worn part?
FG MkII G6 Ecoboost in Lightning Strike
block58 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2012, 05:05 PM   #2
SSD-85
Default Re: Shaking steering wheel
Does it only happen when the car's in motion? Do you have any play in the steering wheel? (ie: steering wheel turns a fraction but doesnt move the car)
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2012, 05:58 PM   #3
block58
block58's Avatar
There isn't excessive play, what I would imagine is normal.
The steering wheel can be lifted up and down slightly when the car isn't moving.
Old 16-11-2012, 06:27 PM   #4
SSD-85
It might be just your tilt adjuster is worn
Old 17-11-2012, 12:03 PM   #5
mik
mik's Avatar
bearing in the high end of the steering column kaput?
Edit: thinking about it, mines got a few k`s on it 200,xxx + k`s and it`s still tight as bell, it occurs to me something that has come loose sounds more likely?be interested to hear what you find.
Old 17-11-2012, 06:34 PM   #6
block58
block58's Avatar
Will have a look at some stage tomorrow, thanks for the tips
