Old 18-11-2012, 11:30 PM   #1
hales231271
hales231271's Avatar
Default Au3 xr8 TDC Marks
Hi All
What are the marks on the factory balancer for the 220kw balancer?
Need to change cam sync and would like to find TDC.
The marks currently on there are extremely difficult to see.(rust)
Think I can make out "20" which I would assume 20deg BTDC?
Dazza
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2012, 12:36 AM   #2
Nic302ef
Cocoloko
Nic302ef's Avatar
Default Re: Au3 xr8 TDC Marks
get some sand paper and clean it up a little, helps alot.
You will have to remove no.1 spark plug to find TDC on the compression stroke anyway so can check with a probe of some sort (nothing sharp or brittle) when the piston reaches the top before it starts to drop off again. Last thing you want is the sync sensor to be 180Degrees out lol.
94 ED XR8 Sprint: SVO alloy heads, FMS F303 cam, AU EECV ECU, T5, on going build.
2010 Territory: family bus.
79 P7 LTD 351.
Nic302ef is offline   Reply With Quote Multi-Quote with this Post
