06-01-2013, 06:19 PM | #1 | ||
i am getting a rubbing noise on right rear when i put foot on brake it also stays there for a few seconds after moving again.
wayne |
07-01-2013, 08:57 AM | #2 | ||
5.6L x 2 pilot
My guess Wayne would be your rear brake pads need replacing. You will also need to get your rear disks machined if possible, but more likely replaced. The rubbing you are hearing is most likely the metal frame of the brake pad rubbing on the disk. This genereally renders your disks as useless - generally throw aways because of the metal on metal damage.
Get it checked asap. Stu
07-01-2013, 10:48 AM | #3 | ||
+1,
definately check it out asap. also with the noise hanging on for a second or so after you have used the brakes. it possibly has sticky caliper slides? or the disc pads might not be moving freely in the calipers too?
Money Talks, but all i ever hear is it saying Goodbye!! |
