Old 06-01-2013, 09:59 PM   #31
TheInterceptor
Cruising...
TheInterceptor's Avatar
Default Re: Coolant dissapearing into nothingness AUII
Originally Posted by xrghiawagon View Post
Mike, did you get the pump and install it?
Hey Tony, got the pump, holding out for a radiator which ill order soon, if im going to drain the system, i may aswell do both in the one hit... 4000kms away from the 150,000k service so thus far so its timley, next Saturdays job
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 12:49 AM   #32
peterljohnson55
peterljohnson55's Avatar
Best to check that the heater pipe isnt rusted at the end where it fits into the o-ring (as mine does). If it is rusting there you will probably find a new o-ring wont solve the problem.
Suggest you first try a cooling system hole sealer as the hole may be just fine enough that this will solve the problem. (here is an example http://www.oneforceaustralia.com.au/...-system-repair) It's was a less-than-10-bucks solution, that worked for me.
(Given its state, tho, I will be replacing the pump in due course when $$$ permit, along with all cooling system hoses, drive belt and pulleys, etc. I am progressively buying these items now so it isnt a big hit on my bank account all at once).
If/when you do replace the pump, and the heater tube is rusty, you will have to cut off the end of the rusty end of the tube. This tube is no longer available from Ford spares and I doubt the wisdom of using a 2nd hand tube.
My plan is to thread the hole in the back of water pump and fit a brass barbed-fitting with cooling system sealant. ... NOTE: THE FOLLOWING EXAMPLE MAY NOT BE THE CORRECT SIZE ... http://www.ebay.com.au/itm/170900774...84.m1436.l2649
I'll then close the system using a short-as-possible cooling system hose, and double-clamp each end along with some cooling system sealant.
Last edited by peterljohnson55; 12-01-2013 at 12:52 AM. Reason: edit: added cooling system sealant.
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 01:34 AM   #33
peterljohnson55
Some discussion here on the heater tube
http://www.fordforums.com.au/showthread.php?t=11368212
Old 12-01-2013, 04:21 PM   #34
TheInterceptor
Cruising...
Hey Peter!
Never liked those stop-leak things! So i wont be going there.
Ooh, thats a great idea! Hopefully mine isnt rusted out but thats a great solution! Definitley keep that as a plan B incase it is cactus.
Thanks!
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
Old 12-01-2013, 07:14 PM   #35
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
I only use a bit of sealant around the o-ring so it seals perfectly and lasts me a few years.
The last water pump I did (funnily enough in my car) I didn't use any, and long behold I've got the same issue as TheInterceptor does now.
The surface was perfect, as was the pipe, but the pipe always has the possibility to leak.
Awesome, you coming up here to do the full major or what?
Edit: I've got a brand new heater tap here FYI.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2013, 07:43 PM   #36
TheInterceptor
Cruising...
Maybe, was gunna do it in the driveway and make a mess for my neighbors to get angry over You workin on Saturday?
Yes i know haha.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
Old 12-01-2013, 07:53 PM   #37
XRGhia
meh.
XRGhia's Avatar
Nope. Not working.
Or even do it tomorrow if you want.
Old 12-01-2013, 07:59 PM   #38
TheInterceptor
Cruising...
Sweet, ill let you know during the week, my new radiator should hopefully show up at work in the next 4 days. Still a bit short of 150,000 so no oil/filter change just yet...
Tomorrow im workin..no can do.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
