Old 03-01-2013, 10:09 PM   #1
ben131185
Default series 1 brake rotors
starting to feel some slight shudder again. not too bad yet but will need some attention in another service or 2.
i think i've done about 90k since i had new rotors put on, so i guess it hasnt
been too bad.
i can probably get them machined, but is it worth it?
or should i just get new slotted or drilled rotors?
i was told by a mate who had drilled rotors that they were good, til he took it in for a service oneday and the mechanic said they had cracked between the holes.
any opinions please?
ben131185 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 10:47 AM   #2
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Default Re: series 1 brake rotors
A common problem with drilled rotors is that they do crack between holes. Slotted are more than adequate for street use, and usually a nice upgrade performance wise.
As for machining vs replacing, that is up to you based purely on finances. Slotted new would be the way to go if you can afford it.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 11:12 PM   #3
robbyj
Rob
robbyj's Avatar
i got some RDA slotted rotors for mine when the stock ones needed replacing.
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2013, 09:30 AM   #4
GK
Walking with God
GK's Avatar
Thumbs up Re: series 1 brake rotors
I would go the RDA slotted option too.
Better still, a S2-3 / B series upgrade on the front is the go.
I had this done on my S1 wagon and it made a vast improvement.
Have a read here.
http://www.fordforums.com.au/showthr...69#post2720169
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 05-01-2013, 09:42 AM   #5
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Go with GK's advice
Uk
Old 05-01-2013, 04:06 PM   #6
Sox
RIP...
Sox's Avatar
been too bad.
If there's plenty of meat on the rotors, then it's definitely worth machining.
If they're almost on the wear limit, then replace.
If they're only shuddering a small amount after 90k, you're doing well.
Having said all that, if you can live with the slight shuddering, and they have plenty of meat left, don't do anything.
Oval Everywhere...
Old 05-01-2013, 05:26 PM   #7
ben131185
thanks for the replies guys.
i like the sound of the rda slotted rotors.
the s2/3/b series brake upgrade would be nice but i'm not sure i want to spend the time and money on that at the moment, also not long had a new hub assembly on the front left side due to a noisy wheel bearing so i'd be pretty much wasting that.
shudder isn't bad yet so will probably put up with it for a while longer and then see how much is left and decide on machining or upgrading to slotted.
and yeah i haven't done too bad, 90, 000ks over about 7 years is ok for these brakes, i try to look after them but the misses mainly drives it now and she's a bit harsher on them.
Old 08-01-2013, 02:00 PM   #8
Reaper8
Reaper8's Avatar
for the S2 upgrade you only need the lower control arms, swaybar mounts and swaybar. everything else is the same. I did the upgrade on mine got everthin from the wreckers for $100 and put new bushes in the control arms and took less than a day to install. well worth it and gives you more options on rotor and swaybar upgrades later.
Reaper8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2013, 07:19 PM   #9
ben131185
$100 sounds worthwhile.
Old 17-01-2013, 06:21 PM   #10
SVR73
Mr Polish
I put DBA 4000 series slotted rotors on the front of my AU1 XR6 and it's the best money ever spent on it so far. Time to replace my front and rear pads again soon as the rear rotors/pads have been on there since I bought the car in 2004 with 40K on the clock. it does probably 1,000 km a year these days, ain't been seen at a show for seven years.
shop around when buying slotteds - massive difference in price between states and even suppliers in the same state. anywhere from several dozen to a couple hundred dollars difference in price for just the front rotors
SVR73 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2013, 12:41 PM   #11
sly
Sly like a G6
sly's Avatar
and the spindles (aka steering knuckles)
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
