Old 27-11-2012, 06:02 AM   #1
Lajon
Default another handbrake thread!
G'morning all, I'm trying to work out what the noise is from the back of au lane... i have adjusted the handbrake a few times but it may still be squeaking.... is their a way that i can remove it safely from one side of the car so that i can make sure that is what the sound is?
Lajon is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2012, 09:52 AM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: another handbrake thread!
typical AU handbrake the drum wears out of round and you can never adjust enough to work without noise. the solution is new rotors and handbrake shoes . make sure you adjust to specs and don't drive with the handbrake on. problem solved
[SIGPIC][/SIGPIC]
Rides:
Old 27-11-2012, 01:06 PM   #3
Lajon
yes that is what i'll do if its definately the problem but I want to make sure it is for sure... is there a way that i can remove the handbrake from just one side?
Old 27-11-2012, 04:37 PM   #4
FGII-XR6
FGII-XR6's Avatar
for testing just back the handbrake brake shoes right off and the noise will go disconnecting the cable will do nothing as the shoes will still be touching
[SIGPIC][/SIGPIC]
Rides:
Old 17-01-2013, 08:41 PM   #5
paultx3i
Thanks for that mine must be an out of round drum causing the shoes to wear more than normal
paultx3i is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2013, 06:38 PM   #6
AU Mont
theres a helpful doco with pics somewhere here how to replace handbrake shoe
ive owned 2 AU's, and both had noisy shoes even after being replaced with new.
in the end i gave up trying to adjust it perfectly, and loosened the shoe at the rotor, so then it would take about 10 clicks of the handbrake lever to fully engage. No noise, and handbrake worked perfectly.
AU Mont is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2013, 10:19 AM   #7
peterljohnson55
peterljohnson55's Avatar
Had mine adjusted by handbrake specialists as it wouldnt hold and made heaps of noise.
So I then replaced the rotors and shoes, and that did the job and has lasted for ages.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
