10-02-2013, 09:29 AM | #1 | ||
I have BF xr6 and tried led globes in the indicators (rear only)and they flash like crazy, what needs to be done to slow them down.
10-02-2013, 01:03 PM | #2 | ||
Issue is not enough load on the Blinker circuit (due to LEDs drawing less current than normal bulbs). You need to either replace the flasher unit to one that is LED compatible or add a resistor/bulb to each side of the car
10-02-2013, 03:55 PM | #3 | ||
Yep, you can't just replace the indicator bulbs with LED's. Nor the brake light bulbs.
11-02-2013, 03:17 PM | #4 | ||
Can't change relay as I believe it is part of electronic system. How does the resistor fit into the system.
11-02-2013, 03:26 PM | #5 | |||
The value and rating of the resistor will depend on the original rating of the bulb as it has to emulate its current draw. e.g. if it was a 24w bulb it would draw 2 amps at 12v (2a x 12v) so your resistor would be 6 ohms (12v / 2a). The resistor would have to be rated at least 5w or preferably 10w so it does not overheat easily. If you spend all day in traffic and indicate constantly then an even higher wattage would be prudent. |
11-02-2013, 06:58 PM | #6 | ||
Great, thanks for the help
12-02-2013, 08:25 PM | #7 | ||
globes plus resistors was the correct answer. Splice and solider the loom.
Can I ask why your bothering? |
12-02-2013, 08:30 PM | #8 | ||
Yeah I blew a loom on one side with so called LED brake lights.. Lesson learned.
FG XR6 Turbo (Manual) - 301rwkws @ 15psi ---------- Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's |
12-02-2013, 08:34 PM | #9 | ||
12-02-2013, 10:36 PM | #10 | ||
Thailand Specials
Narva makes LED load resistors I think.
http://www.narva.com.au/products/bro...oad-resistor-3 Solder it in, don't use the scotch lock or it won't work after you drive out of the drive way. |
13-02-2013, 06:50 AM | #11 | ||
13-02-2013, 07:17 AM | #12 | ||
Oo\===/oO
Yes, the Falcon is 100% australian, no parts at all from Mexico, Thailand, China etc...
13-02-2013, 06:16 PM | #13 | ||
Thailand Specials
13-02-2013, 07:15 PM | #14 | ||
Sorta, my cars got a few Chinese parts.
When it's cheaper to get alloy bends shipped from china then walk across the road to supercheap then why not. Better quality too believe it or not. Catch can's from America and was nearly half the price of anything similar I could find local. Few silicone bends from the UK etc.. Most wedge LED's i've bought over the years are from china too just no more important electrics. Allot of shops important the same stuff just add their bit on top.
FG XR6 Turbo (Manual) - 301rwkws @ 15psi ---------- Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's Last edited by Dash_XR; 13-02-2013 at 07:20 PM. |
13-02-2013, 08:52 PM | #15 | ||
Peter Car
13-02-2013, 09:15 PM | #16 | ||
13-02-2013, 09:27 PM | #17 | ||
Pretty sure he was being sarcastic.
I will always try and support Australian built cars but if the aftermarket gets greedy then I have no problem going overseas.
